VW Habanero Orange is one I took a shine to the other day.
Project 'once'
#881
Posted 10 July 2015 - 12:52 PM
#882
Posted 10 July 2015 - 01:16 PM
His is currently at the paint shop. Lol so hopefully it should be done in 18 monthsGood idea, assuming his paintshop finishes it in the next 18 months.Will hopefully be able to use him as a guinea pig
#883
Posted 10 July 2015 - 01:17 PM
Yup nearly shortlisted it myself when on the launch. Then saw some pics of a car in habanero in uk light and changed my mind...
If only i lived somewhere where it was permanently sunny
#884
Posted 10 July 2015 - 01:19 PM
#885
Posted 10 July 2015 - 01:24 PM
I may end up with boring old safe grey at this point... which will at least please Naomi
#886
Posted 10 July 2015 - 01:25 PM
What about volcanic orange?I may end up with boring old safe grey at this point... which will at least please Naomi
#887
Posted 10 July 2015 - 01:27 PM
Which is the colour doctorfrag couldn't get his VX painted right? Sounds like a no go.
#888
Posted 10 July 2015 - 01:30 PM
#889
Posted 10 July 2015 - 01:34 PM
Yh true but light have just been the paint shop being funny about it.
To be honest, I don't think it's far from sakhir orange and suffers similar problems in low/dull light
#890
Posted 10 July 2015 - 01:56 PM
Previously know as Westkenbiscuit on the Saab b207 threadWho's "Bill"?
But for a Harrop that's a surprisingly lowish rpm where his makes the 398 max power.
(but from that number a similar build 2.0 should make 360-ish...)
Looked there and according to the info there:
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]3. Westkenbrit. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Now with a full 3" exhaust system => 398BHP... (Tullet 3" mani + custom 3" double muffler system?)[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]He's still on the Dutch software I assume? then you could compare the dyno plot with the internal OBD road power measurements. [/color]
Edited by Exmantaa, 10 July 2015 - 01:56 PM.
#891
Posted 10 July 2015 - 02:00 PM
[/color]
I think Bill was on Dutch software, but I have a feeling that's he now on the EMU Ecu. MBR should be able to confirm though
#892
Posted 10 July 2015 - 02:01 PM
I'm sure bill we be doing some mapping soon as it Dosent look like he has done much fuel learning
But I will urge him to do power runs as soon as possible to see the accuracy
But which will be right obd or the RR
Now there's a conversation topic
Edited by CHILL Gone DUTCH, 10 July 2015 - 02:04 PM.
#893
Edited by CHILL Gone DUTCH, 10 July 2015 - 02:02 PM.
#894
Posted 10 July 2015 - 02:08 PM
On most of the boost levels we are dealing with here you shouldn't need to go under 12 in my experience if you keep the charge temp reasonable. However if charge temps change significantly that is what a correction table is for, if the temp goes high for some reason it goes richer.
We are only talking about 0.8-0.9 bar of boost, not like a stg 4-5 turbo at 1.3-1.6bar boost.
Ehhh... A harrop (2.0) engine will typically see around 1.3 bar boost with a big 80mm pulley, depending on how well the head and exhaust flow. A 2.2 probably a bit less.
(we once logged 1.58bar boost with a clogged cat and no power at Zandvoordt)
Charge temps with the above on sustained full blast and the dual pass/PA cooler system; think 80-90°C. And only corrected for if the MAP sensor is modded to a TMAP system...
As said before, most cheap-ish Wideband systems can deviate quite a lot around 12AFR. so keep it safe. (and monitor for knock)
#895
Posted 10 July 2015 - 02:12 PM
Back to my car for a second though, I've just spoke to Sam from Jamsport who mapped the car and cleared up a couple of things.
I don't have AFR, ignition or boost logs at the moment. Obviously these are all ok, but long story short they're about to move premises and onto a new dyno, which will allow them to log these better. For now, all the logging and monitoring of this information is done within the ECU.
Regarding the scale on the graph, it isn't entirely accurate. It was set at the same ratio as when Sam mapped Bills car, to allow that comparison. So where it shows the peak power is made at approx 5,750rpm, it is actually making this around 4-500rpm later at 6,250-6,350rpm. The cut off, where it is revved too, is actually at 7,200rpm, not the 6,650rpm it shows on the plot. 7,200rpm was used simply because Sam felt there was no need to rev further since it was already dropping off.
Due to what Sam suspects is a geometry issue - I'm not sure if the car has ever been set up since the suspension etc has been bolted back on - he said it felt like the left wheel was wheelspinning slightly. He could hear a squeal when backing off, as if it was gripping again. The boost does tail off slightly towards the top-end, but not enough to warrant further investigation in his opinion, so while he agrees it could be belt slip, it wasn't his first thought.
I have confirmed that the dyno does measure in lb/ft, so this engine did make a peak of near 350lb/ft between around 4,000rpm to 4,700rpm (adjusted for the scale being out of sync). In new money that's 475Nm....
I'm slightly happier to hear all of this, as it at least suggests that the power is delivered slightly further up the rev range, which is more in line with what we are expecting.
Having discussed it with him and Matt, the plan is to adjust the cam timing. I definitely don't know much about cams, but looking at it all I can't help but think the timing is slightly out and they are making all their power in the mid-range, rather than further up as expected. So hopefully it'll allow both the bhp and torque line to smooth out their rate of rise and progressively increase a little further towards the redline.
Hopefully that makes sense, and clears a few things up. And hopefully we can get the cams re-timed ASAP, and maybe even try out a 3-inch manifold to check whether that is having an effect or not also.
#896
Posted 10 July 2015 - 02:13 PM
[color=rgb(40,40,40);][font="helvetica;"]He's still on the Dutch software I assume? then you could compare the dyno plot with the internal OBD road power measurements.
[/color][/font]
He should do some power measurements exactly as it was measured on the RR, without any additional fuel learning etc. That's the only way you could comparethe OBD measurements with these plots.
Not saying which one is right ... They're just numbers.
#897
He sent me his file the other day From obd tuner Unless it's a old file
Ok my bad. Must still be on OBD then. I just thought he might have changed since Sam was used for some of the mapping, as I know Sam is particularly familiar with the EMU ecu
#898
Posted 10 July 2015 - 02:16 PM
#899
Posted 10 July 2015 - 02:25 PM
350 lb ft does need applauding That's a lot
surprised me too
Now if it's the cam timing, and we can shift that up the rev range, we'll be good
#900
surprised me too
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
