is there cam overlap?
whats your idle vacuum?
stg1 zzp cams have a lsa of 109 the stg2 is 112
Posted 10 July 2015 - 02:28 PM
Posted 10 July 2015 - 02:31 PM
asking wrong person Steve
Posted 10 July 2015 - 02:32 PM
Can a mod please change the title to the on going project
fcuk off
Posted 10 July 2015 - 02:33 PM
Lolfcuk offCan a mod please change the title to the on going project
Posted 10 July 2015 - 02:34 PM
It's still project Once. I've not finished and gone back to sort things, this is just fine tuning in the middle!
Posted 10 July 2015 - 02:35 PM
Regarding the scale on the graph, it isn't entirely accurate. It was set at the same ratio as when Sam mapped Bills car, to allow that comparison. So where it shows the peak power is made at approx 5,750rpm, it is actually making this around 4-500rpm later at 6,250-6,350rpm. The cut off, where it is revved too, is actually at 7,200rpm, not the 6,650rpm it shows on the plot. 7,200rpm was used simply because Sam felt there was no need to rev further since it was already dropping off.
Due to what Sam suspects is a geometry issue - I'm not sure if the car has ever been set up since the suspension etc has been bolted back on - he said it felt like the left wheel was wheelspinning slightly. He could hear a squeal when backing off, as if it was gripping again. The boost does tail off slightly towards the top-end, but not enough to warrant further investigation in his opinion, so while he agrees it could be belt slip, it wasn't his first thought.
I have confirmed that the dyno does measure in lb/ft, so this engine did make a peak of near 350lb/ft between around 4,000rpm to 4,700rpm (adjusted for the scale being out of sync). In new money that's 475Nm....
475Nm is unusually high for a 2.0 Harrop engine. Dyno measurement numbers are debatable, but that would be almost 50% more torque than our 325Nm measurement. (And only due to "better efficiency" of head/cams and exhaust... )
Vocky timed your cams, right? So he will have dialed them in to the prescribed Comp cam timing.
Still think you had wheel spin that skews the measurment. We normally see the Harrop boost rising (with 80mm pulley) till max rpms, as it's simply a fixed volume airpump pushing agains the engine's flow restrictions.
Edited by Exmantaa, 10 July 2015 - 02:37 PM.
Posted 10 July 2015 - 02:38 PM
Still think you had wheel spin that skews the measurment. We normally see the Harrop boost rising (with 80m pulley) till max rpms, as it's simply a fixed volume airpump pushing agains the engine's flow restrictions.
Nope, cams dialled in by MBR, not Vocky.
Agreed the torque figure comes across as ridiculous...
Posted 10 July 2015 - 04:39 PM
Afr will be 14's at idle. Late 13's low load running to late 12's on max boost.
Cock up alert, was just talking to someone about this and spotted my mistake. I meant Low 12's not late 12's at max boost. Sorry
But still not 11's
Posted 10 July 2015 - 06:06 PM
Posted 10 July 2015 - 06:07 PM
they print graphes out for turbo owners on A3 paper
Posted 10 July 2015 - 06:38 PM
Thought it was a seismograph roll.
Posted 10 July 2015 - 07:05 PM
you know, I think I get the same dips as well up top. Especially since I fixed the CC pump. Maybe the ZZP cams. What would be telling would be Lee or Nick, think they've got Blower cams?Good spot ray I see it now But what's causing it
Posted 10 July 2015 - 07:06 PM
i could find one of nicks
i have a very large collection of maps and power runs
Posted 10 July 2015 - 07:19 PM
Posted 10 July 2015 - 07:22 PM
if i start the power run at 4 or 5 k rather than lower it still does it
Posted 10 July 2015 - 07:28 PM
i believe mine is so prominent because of my large pulley and its the resistance of the manifold and the boost having to push past it
Posted 10 July 2015 - 08:11 PM
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
