Project 'once'
saab b207 supercharged m62 ats dtc composite worx re-spray coupe
1145 replies to this topic
#941 fezzasus
Posted 11 July 2015 - 08:13 AM
Probably valve overlap if the cam type is consistent.
#942 CHILL Gone DUTCH
Posted 11 July 2015 - 08:24 AM
You do no silver will add 40 hp but will lose 28 ft lb
You're all torque Chris
I only have 300 ft lb 😜
#943 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 July 2015 - 08:26 AM
I only have 300 ft lb �
Then we can't be friends anymore �
#944 oakmere
oakmere
  • 2,143 posts
Posted 11 July 2015 - 09:10 AM
As it is the harrop cars that really show this dip up I think it is flow issues with the inlet manifold.
#945 CHILL Gone DUTCH
Posted 11 July 2015 - 09:22 AM
Afr will be 14's at idle. Late 13's low load running to late 12's on max boost.
Cock up alert, was just talking to someone about this and spotted my mistake. I meant Low 12's not late 12's at max boost. Sorry
But still not 11's
Don't think your running as lean as you first thought ( or I first thought ) after looking at the maps and various conversations
I've had with various people
Here is a more standard target AFR
And here is a MBR AFR on Bills car
Now on the face of it it looks like the settings on matts map his afr are running at 12.5 WOT depending on what pressure is running
But if you look at the correction numbers under the target AFR table it actually gives a different story
It only actual 12.5 of inlet temps are below 51 degrees
Where as a normally it's at 71 degrees before extra fuelling is added
So in effect if temps could be controlled on a RR than the 12.5 AFR would be being used for max powers but in reality on the road temps are very rare are below this temp
So matt has cleverly used the Tmap sensor on his calibration to control the power
At the same time keeping it safe enough on road/ track use when temps are likely to be higher
Edited by CHILL Gone DUTCH, 11 July 2015 - 09:28 AM.
#946 CHILL Gone DUTCH
Posted 11 July 2015 - 09:31 AM
I posted the wrong graph at first But have now edited it
#947 CHILL Gone DUTCH
Posted 11 July 2015 - 09:36 AM
That's my thoughts And because I run a bigger pulley my car finds it harder to push past it so looks like I suffer more
Edited by CHILL Gone DUTCH, 11 July 2015 - 09:43 AM.
#948 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 11 July 2015 - 09:59 AM
Blue by the way best colour...,, Chis can we move the either the Dutch ecu tread or yours so we don't annoy the owner of this one.
#949 CHILL Gone DUTCH
Posted 11 July 2015 - 10:31 AM
Moved sorry GL http://www.vx220.org...79#entry1803335
#950 Bargi
Bargi
  • 4,483 posts
Posted 11 July 2015 - 01:42 PM
[quote data-cid='1803305' name='fezzasus' timestamp='1436602431' post='1803305']Probably valve overlap if
Insomuch as they are high lift cams. You've got blower and the zzp Stage 2.
What's common so far is they are all Harrop. Would be interesting to see the same with a M62 just to eliminate the SC.
My semi technical brain tells me cama should help those RPM. What I've learnt over the years that things are never straightforward
#951 CHILL Gone DUTCH
Posted 11 July 2015 - 01:47 PM
Here is my stage 3
And it's still there
M62
Edited by CHILL Gone DUTCH, 11 July 2015 - 01:48 PM.
#952 CHILL Gone DUTCH
Posted 11 July 2015 - 01:50 PM
And it's there on my stage 2
No cams
#953 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 July 2015 - 02:57 PM
And it's there on my stage 2 No cams
So inlet manifold. Which we know isn't ideal. So who's going to remove laminova to see if that helps (and cool it another way)
#954 The Batman
Posted 11 July 2015 - 03:07 PM
I guess it's either you are lee who are running the sandwich plates
#955 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 July 2015 - 04:49 PM
Surely sandwich plates wouldn't be enough? Now, sandwich plate and water injection? Acidpopstar where are you?
#956 CHILL Gone DUTCH
Posted 11 July 2015 - 04:53 PM
Oakmere had the dip on his NA on a CS map So maybe it's something else Didn't someone mention some kind of harmonics
Edited by CHILL Gone DUTCH, 11 July 2015 - 04:56 PM.
#957 CHILL Gone DUTCH
Posted 11 July 2015 - 04:56 PM
So could it be a harmonic issue that is disturbing the flow? How does the graph look if you drop part throttle to say 4k and push back up? I presume it would be identical, but if it is different then something is indirectly affecting the results, rather than map/harrop/Mani rtf.
Here
#958 fezzasus
Posted 11 July 2015 - 05:04 PM
I still maintain it's valve overlap. Here's why:
At low RPM the valves close following the profile of the cam, as you go up in speed, the mass of the valve leads to a slight valve float. In other words, the closing of the valve doesn't follow the cam profile but instead is restricted by the speed the valve can accelerate at. This has been addressed somewhat by using stronger springs, but they add extra mass so really just delay the issue.
This dip appears to be at around the same RPM on engines with similar cams and springs. I would suggest that systems with original springs will see this dip lower down the rev range, however it would be very rare to find an engine with different cams but the same springs.
#959 CHILL Gone DUTCH
Posted 11 July 2015 - 05:08 PM
Ok fez that's a new idea so now we need people to ID there cams and springs along with there graphs if possible
#960 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 July 2015 - 05:28 PM
Ok so I'm stage 2 ZZP cams, Supertech double valve springs
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
    Bing (4)
