Edited by CHILL Gone DUTCH, 11 July 2015 - 05:31 PM.
Project 'once'
#961
Posted 11 July 2015 - 05:31 PM
#962
presumably at 0° adjustment with standard cam pulley
#963
Posted 11 July 2015 - 05:32 PM
#964
Posted 11 July 2015 - 05:36 PM
Edited by CHILL Gone DUTCH, 11 July 2015 - 05:38 PM.
#965
Posted 11 July 2015 - 08:21 PM
I still maintain it's valve overlap. Here's why:
At low RPM the valves close following the profile of the cam, as you go up in speed, the mass of the valve leads to a slight valve float. In other words, the closing of the valve doesn't follow the cam profile but instead is restricted by the speed the valve can accelerate at. This has been addressed somewhat by using stronger springs, but they add extra mass so really just delay the issue.
This dip appears to be at around the same RPM on engines with similar cams and springs. I would suggest that systems with original springs will see this dip lower down the rev range, however it would be very rare to find an engine with different cams but the same springs.
Why is it a dip? If the valves start getting floaty due to revs, then should more revs not exacerbate that and power die off? Why does the power recover?
#966
Posted 11 July 2015 - 08:22 PM
#967
Posted 12 July 2015 - 08:34 AM
Because the loss will be constant, increasing revs will put more air and fuel in which allow for more power.
#968
Posted 12 July 2015 - 09:30 AM
#969
Posted 12 July 2015 - 09:59 AM
#970
Posted 12 July 2015 - 10:11 AM
Ask Vocky, he's done them allThe head was designed for low down torque not high rpm power and very few of these engines have much porting work done on the intake ports. Could this be a restriction?
#971
Posted 12 July 2015 - 10:41 AM
#973
Posted 12 July 2015 - 11:27 AM
Does anyone know would our friends at CS be able to provide the raw dyno data of the SC runs so someone could graph them to scale of the more recent results for a better comparison?
Upload them to dynoplot.co.uk, as per my signature. Then you can compare anything/everything on the same scale.
#974
Posted 12 July 2015 - 07:58 PM
well im now on http://www.dyno-plot.../dyno/about.htm
not as easy as you think to get your plot up lol
Edited by CHILL Gone DUTCH, 12 July 2015 - 08:00 PM.
#975
Posted 12 July 2015 - 08:21 PM
#976
Posted 12 July 2015 - 09:22 PM
#977
Posted 13 July 2015 - 06:38 AM
Then trace it so dyno- plot rescale itYou just submit a scanned image?
#978
Posted 13 July 2015 - 02:46 PM
#979
Posted 13 July 2015 - 04:55 PM
Cocked up the graph, how the hell do you delete it?
#980
Posted 13 July 2015 - 04:57 PM
just over ride it
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
