Project 'once'
#101
Posted 29 January 2014 - 01:36 PM
#102
Posted 29 January 2014 - 01:40 PM
RSRs are a brilliant tire, really liked the front end especially
Good stuff. Assuming and hoping I have no size issues (ABS etc) then I think they look to be a steal at £365 for all four.
G
#103
Posted 29 January 2014 - 02:12 PM
Here you go,
I'll do all the work for you shall i?
http://www.racepads....alogue_2014.pdf
2 pot Pad ref: 2593
4 pot (BBK) Pad ref: 4349
Rears Pad ref: 1682
best i can find them for is for a full set of 4 pot (BBK) fronts and standard rears:
RS14 compound: £324.79 inc VAT
RS42 compound: £294.16 inc VAT
Probably a bit of postage on that. Thats around 5% saving on Elise parts.
#104
Posted 30 January 2014 - 04:45 PM
Today's package arrived: new in primer Turbo ear.
#105
Posted 30 January 2014 - 05:12 PM
looking at the friction graph that's will be similar to the RS42 front and RS14 rear I've run for years.RS19's front, RS14's rear on mine and I couldn't want for better braking. The distribution and bite is fantastic and having an endurance pad up front with an aggressive on rear means you need little time to make work.
please don't ruin yet another NA with those stupid sticky out ears, especially if you're under the illusion that it will aid coolingToday's package arrived: new in primer Turbo ear.
Edited by Winstar, 30 January 2014 - 05:13 PM.
#106
Posted 30 January 2014 - 05:31 PM
Aha,
Just the man I wanted to see here.
Definitely interested in hearing how is best to cool this thing.
First off I'm afraid this NA will be ruined by the VXT ears, as it already has some. Since the cutting has already been done, it would probably be harder not to fit them to the new one.
I was going to use one to feed some air into the airfilter?
But back to the cooling; this car is going to have a Coupe conversion ala Cliffie, Lee etc with the roof scoop. Rumour has it, that on the Exige certainly, the roofscoop collects warm dirty air from the front of the car and if it was to take clean air it would have to project out another 6-12inches from the windscreen top. That right? I was going to use the roof scoop to force more air into the engine bay in a bid to help cool it.
Also, one thing I'm generally not keen on is the cut outs everyone does at the rear of the car - i'd rather keep my rear clam intact in that way.
I think I read that the NACA ducts in the undertray do quite well at helping with the cooling. Is there any reason to fit a few more in the undertray for this. And what is the best way to get the heat out of the bay? Can I get away without cutting the rear of my VX up?
And finally, I also thought I heard that fitting the coupe rear but without adding a proper rear wing can induce lift. Is this true? I had planned to fit the coupe rear but with a simple Turbo spoiler (for looks not for aero) but wondering what your thoughts are on it all?
Cheers,
G
#107
Posted 30 January 2014 - 05:37 PM
Fit an extra NACA duct and don't bother with the god awful roof intake. Especially not an extended one (unless you're planning on endurance racing). Worked a treat on mine at dropping temps and your coupe back should have more than enough capacity to vent that extra air without any more hackery.
#108
Posted 30 January 2014 - 05:45 PM
I'd like to at least make some use of the roof intake though Matt, not a fan of having stuff purely for looks if it does nothing (I've got my fingers in my ears about the turbo spoiler). Good news that the NACA duct helped on yours. Question is do I fit one or two extra, and is there anywhere in particular that is optimum?
Oh and don't worry about the extended roof scoop option, it looks sh*t, almost as bad as the noses on current F1 cars. It's just something MB and I had discussed when I mooted using the roofscoop for an intake for the air filter.
G
Edited by Graeme Lambert, 30 January 2014 - 05:48 PM.
#109
Posted 30 January 2014 - 05:49 PM
#110
Posted 30 January 2014 - 05:51 PM
You could try sticking random NACA ducts all over like the F40
One of mine tried to escape at Brands so is now a little shorter after scrapig along the floor!
I did consider, and have seen, mounting a couple on the bodywork somewhere but not sure. Might consider cutting some into the coupe panel somewhere?
G
#111
Posted 30 January 2014 - 08:12 PM
#112
Posted 01 February 2014 - 12:06 PM
If it's been ruined any way then go on.looking at the friction graph that's will be similar to the RS42 front and RS14 rear I've run for years.RS19's front, RS14's rear on mine and I couldn't want for better braking. The distribution and bite is fantastic and having an endurance pad up front with an aggressive on rear means you need little time to make work.
Aha,
Cheers,
G
Fitting the coupe back complicates things as you can see from below the main flow route is to come in from the ears and NACA ducts then out through the engine cover vents. With the NACA ducts providing the flow in the regions it needs it most on the NA with the exhaust a the back of the engine. The problem with the coupe roof is that if you use the front scoop this is going to add significant flow which will block flow from the NACA ducts and the ears. The only way to get around this is to cut the rear clam so the main exit route is from there.
As for the hot air I've just quickly run the model with hot air coming out of the rad vent as because the VX has the strip in the middle of the outlet, which the exige/Europa don't, then although there is a bit of hot air caught in the boundary layer there is a strip of clean/cool air down the centre of the car with the thermal plumes pushed over the sides of the windscreen.With ears
Ear flow rate - 0.66 kg/s
NACA flow rate - 0.12 kg/s
Without ears
Ear flow rate - 0.15 kg/s
NACA flow rate - 0.15 kg/s
#113
Posted 01 February 2014 - 05:35 PM
So long and short of it, if I want to use the roofscoop and ears I need to get the air out of the back of the car somehow? And to do that I need to cut the rear clam and let it all exit from there?
G
#114
Posted 01 February 2014 - 05:38 PM
G
Unless you space the diffuser, just a thought.
#115
Posted 01 February 2014 - 05:43 PM
G
Would spacing the diffuser be enough though Tom?
Especially as it's a TAT short round, which probably won't look right if too low?
G
#116
Posted 01 February 2014 - 05:46 PM
G
G
I think James has some photos of his spaced by about an inch. I don't think you need massive amounts of rear venting as the area of low pressure behind the car will help pull air through any vent there. I don't know if the boot lets you make the vent under the number plate any bigger, might be worth looking at too.
EDIt: http://www.vx220.org...e-tat-diffuser/
Edited by fezzasus, 01 February 2014 - 05:47 PM.
#117
Posted 01 February 2014 - 05:49 PM
#118
Posted 01 February 2014 - 05:58 PM
Happy to space it a little. If that helps then perfect. To be honest I'm hoping that I can achieve my power goal with less boost than normal due to what we are doing to the base engine (head, cams etc) so might have lower temps to deal with anyway. Could be a pipedream though?I think James has some photos of his spaced by about an inch. I don't think you need massive amounts of rear venting as the area of low pressure behind the car will help pull air through any vent there. I don't know if the boot lets you make the vent under the number plate any bigger, might be worth looking at too. EDIt: http://www.vx220.org...e-tat-diffuser/
Would spacing the diffuser be enough though Tom? Especially as it's a TAT short round, which probably won't look right if too low? G
Unless you space the diffuser, just a thought.So long and short of it, if I want to use the roofscoop and ears I need to get the air out of the back of the car somehow? And to do that I need to cut the rear clam and let it all exit from there? G
#119
Hopefully he'll be back along in a minute then! GWill this not just take air from naca ducts before it's cooled anything? I'm no expert it's just a question Where is winstar when you need him
#120
Posted 01 February 2014 - 06:00 PM
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
