concidering buying the car back and repairing my self,
is there anyone local to the Farnham,Surrey area that has done anything like this beofre and could maybe come take a look at it with me before i concider buying?
Posted 29 January 2014 - 08:24 PM
Posted 29 January 2014 - 08:29 PM
Posted 29 January 2014 - 08:32 PM
Do not buy it back. You cannot repair these chassis. The construction is unique and very difficult, I would say impossible, to attempt yourself.
Posted 29 January 2014 - 08:35 PM
Bodyshop didnt write the car of, just the vaule of repair was £7000 using genuine oem parts and was £1000 over what the insurance was willing to pay!
Posted 29 January 2014 - 08:37 PM
Posted 29 January 2014 - 08:40 PM
They were incorrect. The chassis has been damaged, you can't bond the chassis correctly without putting the whole car into an oven, you can't weld it without weakening it, you can't straighten it without weakening it.
The door mount has been pushed into the door, this has bent the entire structure which is not only part of the chassis, but a load bearing component. Given that your car is relatively standard, your best option is to scrap the car and buy another.
Area circled in purple is damaged. It is not repairable, nor should it be repaired, it will compromise the strength of the entire chassis.
Posted 29 January 2014 - 11:30 PM
So which VX/Lotus specialist did you take it to?Bodyshop didnt write the car of,
Posted 30 January 2014 - 01:23 AM
Posted 30 January 2014 - 08:25 AM
Take a payout and get a new one.
Posted 30 January 2014 - 08:55 AM
the correct position of the door mounting post is outlined in blue, the red is where the door mounting post is on your car
Edited by vocky, 30 January 2014 - 08:57 AM.
Posted 30 January 2014 - 10:21 AM
And this is how it looks on the car:
Posted 30 January 2014 - 10:25 AM
Oooh, that highlights it nicely when in conjunction with vocky's pic.
That's fcuked!
Posted 30 January 2014 - 10:27 AM
Buy it back cheap, turn it in to a track slag.. sell off all the bits you remove to make it lighter..
Posted 30 January 2014 - 10:33 AM
Posted 30 January 2014 - 10:38 AM
If the door mount damage is as bad as stated then would you REALLY want to track a car with a compromised chassis?
Posted 30 January 2014 - 10:53 AM
We can't see the actual damage to the chassis.
All we see is that the bolted doorhinge has been ripped out of the allow. To see the state of the alloy, the sill needs to come off.
Posted 30 January 2014 - 01:58 PM
All we see is that the bolted door hinge has been ripped out of the alloy.
no, the door hinge should stick outwards like the picture of the bare chassis above, this one has been smashed backwards bending the actual alloy cross member which held the hinge, so quite some impact
Edited by vocky, 30 January 2014 - 01:58 PM.
Posted 30 January 2014 - 02:28 PM
Yes, i see it now. That's pretty much toast indeed.
Posted 30 January 2014 - 02:34 PM
That's a great pic smiley, it highlights the damage even better than the previous pics
Edited by Gedi, 30 January 2014 - 02:34 PM.
