Flywheels - B207 And Z22 - Interest
b207 z22 flywheel
126 replies to this topic
#1 Matthew Bentley Racing Ltd
  • 774 posts
Posted 04 February 2014 - 12:13 PM
Just gauging interest. I am getting prices to make B207 and Z22 flywheels (same dimensions just different bolt pattern).
How much interest is there?
Matt
#2 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 04 February 2014 - 12:20 PM
Well you know you have at least one customer... From speaking to others, and looking at my project thread I would suspect you'd have over 10 serious buyers pretty easily. .org list; 1. Graeme Lambert 2. 3. 4. 5.
#3 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 04 February 2014 - 12:30 PM
1. Graeme Lambert 2. Tony H 3. 4. 5.
#4 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 04 February 2014 - 12:32 PM
I take it these will be lightweight mentalist badboys?
#5 fezzasus
Posted 04 February 2014 - 12:35 PM
Provisionally interested in a Z22 one depending on price (I assume it will be equal or better to the TTV unit)
#6 JG
JG
  • 13,612 posts
Posted 04 February 2014 - 12:45 PM
I'd be interested in two (though i'd need to understand why these would be better than the CS ones)
#7 fezzasus
Posted 04 February 2014 - 12:50 PM
From what I understand from Neil the CS items aren't balanced that well because they use a separate starter motor gear ring.
#8 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 04 February 2014 - 01:38 PM
Aren't the CS ones TTV anyway?
Would the Z22SE ones be a direct fit (you mention different bolt pattern above or is that Z22 vs B207?)
If direct fitment then interested subject to price.
Thanks
#9 fezzasus
Posted 04 February 2014 - 01:42 PM
No, the CS ones are different, they weigh 5.6 kg vs the TTV 4.2 kg.
#10 oakmere
oakmere
  • 2,143 posts
Posted 04 February 2014 - 01:59 PM
I think CS now supply TTV not the old style one
#11 yaaan
yaaan
  • 956 posts
Posted 04 February 2014 - 02:02 PM
:yeahthat: When I was looking to buy mine recently, enquiries to TTV were redirected to CS.
#12 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 04 February 2014 - 03:33 PM
I have a Courtenay/TTV flywheel sat here. It has an integrated ring gear and weighs 4.4kg
#13 Exmantaa
Posted 04 February 2014 - 04:16 PM
Depends on price and design. Personally I find 4.4kg a bit too light, but 5.5-5.8 is fine. Balanced off course...
#14 AMOSS
AMOSS
  • 542 posts
Posted 04 February 2014 - 04:47 PM
I'll be interested in a Z22 flywheel.
#15 CHILL Gone DUTCH
Posted 04 February 2014 - 06:18 PM
The one I got from CS last week weighs 4.5kg ish on my crappy scales
#16 Kieran McC
Kieran McC
  • 3,416 posts
Posted 04 February 2014 - 06:21 PM
My 8 hole pattern fly wheel from CS was made at TTV nice piece of work
#17 Matthew Bentley Racing Ltd
  • 774 posts
Posted 04 February 2014 - 07:05 PM
Ok fantastic. I will get the specs down on paper. They will be comparable or better than the cs/ttv unit. The bolt pattern diff is only z22 vs b207.
#18 oakmere
oakmere
  • 2,143 posts
Posted 04 February 2014 - 07:24 PM
Matt if designing some new ones I would agree with the above. My 4.4kg flywheelcan be a bit of a pain in stop star traffic and hill starts. Though this is less of an issue if running std cams and throttle settings.
#19 techieboy
Posted 04 February 2014 - 07:49 PM
I've had a CS/TTV flywheel in my car for 5 years and it's a single piece flywheel with integral ring gear.
I'll probably be interested in a B207 8-bolt version as long as it's not stupidly light and not stupidly expensive. If they're going to be a similar weight to the existing Z22SE lightweight flywheel, I'll probably look elsewhere or get this standard beast machined down as the whole bottom end will be balanced anyway.
#20 techieboy
Posted 04 February 2014 - 07:50 PM
It's been a long time since mine got bolted onto the engine but that weight sounds familiar and your's looks identical.
Also tagged with one or more of these keywords: b207, z22, flywheel
