Flywheels - B207 And Z22 - Interest
#81
Posted 29 April 2014 - 05:13 PM
#82
Posted 29 April 2014 - 05:46 PM
I can confirm, but would like 5.5kg as a min
#83
Posted 29 April 2014 - 05:56 PM
To be fair I think Matt will be happy to do two batches of weights, so probably can do 5 nd 5.5Kg - though I'm not averse to 5.5kg either.
G
#84
Posted 29 April 2014 - 06:00 PM
Thanks Graeme. Is the general consensus that the c20let clutch and z20let slave cylinder the way to go for a stage 2 SC? I assume that's all that's needed?
You really should be asking someone who might know about these things! Hopefully someone else on this thread can confirm what you need - though I think on SC Stg2 you can just use the normal Z22 stuff? Could be talking out of my arris though.
JG, for sake of clarity can you indicate what bolt pattern/fitment you need (I think it's Z22 but just in case you have something up your sleeve)
1. Graeme Lambert - 8 bolt (B207) - [color=#008000;]confirmed[/color]
2. Tony H - 8 bolt (B207) - [color=#008000;]confirmed[/color]
3. Fezzasus - 8 bolt (B207) - [color=#008000;]confirmed[/color]
4. JG - 5.5Kg min - [color=#008000;]confirmed [/color]
5. AMOSS - 6 bolt (Z22) - [color=#008000;]confirmed[/color]
6. Techieboy - 8 bolt
7. Robin
8. Si220
9. Bill SC (b207 5kg fine) - [color=#008000;]confirmed[/color]
10. Alastair Z22 - [color=#008000;]Confirmed [/color]
#85
Posted 29 April 2014 - 06:23 PM
#86
Posted 29 April 2014 - 06:33 PM
I was on all stock stuff at stage 2 I think it's possible to have oem up to stage 3 but not 100% But stage 2 Deffo ok on stock clutchThanks Graeme. Is the general consensus that the c20let clutch and z20let slave cylinder the way to go for a stage 2 SC? I assume that's all that's needed?
#87
Posted 29 April 2014 - 06:55 PM
i too would prefer 5.5kg if it's an option.
#88
Posted 29 April 2014 - 06:58 PM
3. Fezzasus - 8 bolt (B207) - [color=#008000;]confirmed 5.5 kg if poss.[/color]
7. Robin 8 bolt - [color=#008000;]confirmed[/color]
8. Si220
10. Alastair Z22 - [color=#008000;]Confirmed[/color]
11. Cocopops 6 bolt - [color=#008000;]confirmed[/color]
Edited by fezzasus, 29 April 2014 - 06:59 PM.
#89
Posted 29 April 2014 - 09:17 PM
#90
Posted 29 April 2014 - 09:21 PM
#91
Posted 30 April 2014 - 08:01 AM
Okay Techieboy is out for now, while he deides on what he's doing.
The good news is we still have the required ten to make this go ahead at the low price
1. Graeme Lambert - 8 bolt (B207) -[color=rgb(0,128,0);] Confirmed[/color]
2. Tony H - 8 bolt (B207) - [color=rgb(0,128,0);]Confirmed[/color]
3. Fezzasus - 8 bolt (B207) - [color=rgb(0,128,0);]confirmed[/color] 5.5 kg if poss.
4. JG - 5.5Kg min - [color=rgb(0,128,0);]Confirmed[/color]
5. AMOSS - 6 bolt (Z22) - [color=rgb(0,128,0);]Confirmed[/color]
6. Robin 8 bolt - [color=rgb(0,128,0);]confirmed[/color]
7. Si220 z22 5kg or 5.5kg fine - [color=rgb(0,128,0);]confirmed[/color]
8. Bill SC (b207 5kg fine) - [color=rgb(0,128,0);]confirmed[/color]
9. Alastair Z22 - [color=rgb(0,128,0);]Confirmed[/color]
10. Cocopops 6 bolt - [color=rgb(0,128,0);]confirmed [/color]
Will update as per my prev post later today hopefully.
G
#92
Posted 30 April 2014 - 09:44 AM
8. Bill SC b207 5kg or 5.5kg fine - [color=rgb(0,128,0);]confirmed[/color]
Happy to go 5 or 5.5 kg.
If you end up doing 2 weights then I'll take MB's advice as he's fitting it anyway....
#93
Posted 30 April 2014 - 09:48 AM
#94
Posted 30 April 2014 - 02:30 PM
3. Fezzasus - 8 bolt (B207) - [color=rgb(0,128,0);]Confirmed[/color].
4. Bill SC - 8 bolt (B207) - [color=rgb(0,128,0);][color=rgb(0,128,0);]Confirmed[/color]d[/color]
5. Robin 8 - bolt (B207)- [color=rgb(0,128,0);][color=rgb(0,128,0);]Confirmed[/color][/color]
6. JG - 6 bolt (Z22SE) - [color=rgb(0,128,0);]Confirmed[/color]
7. AMOSS - 6 bolt (Z22SE) - [color=rgb(0,128,0);]Confirmed[/color]
8. Si220 - 6 bolt (Z22SE) - [color=rgb(0,128,0);][color=rgb(0,128,0);]Confirmed[/color][/color]
9. Alastair - 6 bolt (Z22SE) - [color=rgb(0,128,0);]Confirmed[/color]
10. Cocopops - 6 bolt (Z22SE) - [color=rgb(0,128,0);]Confirmed[/color]
Phew, that's better, it was too messy.
[color=rgb(0,128,0);] [/color]
#95
Posted 30 April 2014 - 02:33 PM
How much are they again?
#96
Posted 30 April 2014 - 02:49 PM
£190+ VAT = £228 inc.
#97
Posted 30 April 2014 - 07:33 PM
is there any B&Q pensioner discount available?
#98
Posted 02 May 2014 - 07:43 AM
Update coming on this today, specifically regarding payment, from Matt direct. Plan is for a 50% deposit if everyone is happy with that, probably via direct bank transfer to MBR.
However date of completion for all flywheels to have been made is Mon 26th May. As 'standard' they will be made at 5.5Kg, however if anyone would like lighter a handful can be made to 5Kg instead - unless you specifically request it then your flywheel will be 5.5Kg.
Group buy (list) will run until 23:59 Friday 9th May, which is one week from now, and anyone wanting one after that will have to pay full retail price.
thanks folks
G
#99
Posted 02 May 2014 - 07:51 AM
Sounds good to me.
#100
Posted 02 May 2014 - 08:14 AM
Also tagged with one or more of these keywords: b207, z22, flywheel
The Market Place →
Car Parts For Sale →
Zzp Aluminum Flywheel - 2.0L F35Started by Vladimir , 04 Jan 2019 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts Wanted →
Parts Needed... A Flywheel, Hand Brake Cables, N/s/r Calliper, And AnStarted by sharpz1984 , 10 Jun 2015 ![]() |
The Market Place →
Z22 Lightweight FlywheelStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
