What Is Opcom?
Posted 07 February 2014 - 08:41 PM
Posted 07 February 2014 - 08:51 PM
U480 obd scanner; simple stand alone (handy abroad) and cheap. It can read and clear the codes you have. http://cgi.ebay.co.u...em=271298542958
OPCOM vauxhall maintenance tool; requires laptop plugin. Much more powerfull, and besides reading codes can be used to change car settings, program new keys etc. http://cgi.ebay.co.u...em=400659377652
Scangauge II; on board computer device, that plugs in into obd. Usually mounted permanently in the car. Can monitor a lot of car info, and of course read/clear codes. http://cgi.ebay.co.u...em=261385080723
List of codes:
http://www.speedster.../z22secodes.pdf http://www.auto-edit...z20letcodes.pdf
They all plug into the obd connector, which is dangeling under the middle of your dashborad.
Edited by smiley, 07 February 2014 - 08:52 PM.
Posted 07 February 2014 - 09:29 PM
Posted 07 February 2014 - 09:32 PM
Posted 07 February 2014 - 09:57 PM
yes should be fine, there is a link to the software you need if you search op-com on here. I cant copy link for some reason
Posted 08 February 2014 - 10:45 AM
:Thanks that's what i call a comprehensive reply.
Posted 08 February 2014 - 12:34 PM
, maybe it should be saved to the Guides and Tutorials section?
For that i would like to make it more comprehensive before. (due to the 10min allowed edit times for a post)
Posted 08 February 2014 - 01:36 PM
Opcom software can be hard to install with Windows 7it does not always recognise the drives , Works fine with windows XP
Posted 07 June 2014 - 12:34 PM
Does it work with Windows 8?
Posted 07 June 2014 - 12:38 PM
try itDoes it work with Windows 8?
Posted 07 June 2014 - 12:51 PM
You can also buy a bluetooth dongle that will talk to an android phone and report faultcodes I think ?
Posted 07 June 2014 - 01:00 PM
You can.
But if you need the power of OpCom, you have to get OpCom or take it to a dealership and get their Tech2 on the case.
Posted 07 June 2014 - 01:06 PM
Or a more expensive WiFi adapter if you use an i device.You can also buy a bluetooth dongle that will talk to an android phone and report faultcodes I think ?
