Blown My Vx Up Today Help Needed!
engine blown
105 replies to this topic
#1 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 09 March 2014 - 06:14 PM
So after fitting new gearbox mounts and swapping the cam cover for a newly powder coated on then and a quick detail thought it would be nice to take a nice drive out with the Mrs and ended up at mates. Upon leaving massive rattle from engine it has a sticky lifter but was much noisier. Plus the oil light came on. So took the cam cover off for inspection... Nothing obvious. Put it back together and decided to chance the short journey home. Unfortunately didn't make it and seized the engine. Won't turn over now mate recused me and towed me home. Looks like an engine change is now required. So looking for help from anyone that wants to lend a hand as need to get up and running for Croft on the 4th April. I need a new clutch and cover and new slave and hoping my flywheel is OK I have a B207 to go in looks like sooner rather than later. Gutted would suit my mood right now.
#2 chris_uk
Posted 09 March 2014 - 06:16 PM
did you run it without oil? i cant imagine you would of done tho..
#3 vocky
did the cam cover get sandblasted before powder coating ?
if so throw it away  thumbsup
#4 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 09 March 2014 - 06:18 PM
Sorry to hear that dude. What an arse. Would help but no fcuk all.
#5 The Batman
Posted 09 March 2014 - 06:23 PM
did the cam cover get sandblasted before powder coating ?   if so throw it away  thumbsup
:yeahthat: my mate destroyed his evo 10 engine this way a few weeks back :(
#6 Wreelybro
Wreelybro
  • 1,641 posts
Posted 09 March 2014 - 06:26 PM
Mmm thinking that may of been the culprit. Lesson learned the hard way.
#7 vocky
Posted 09 March 2014 - 06:28 PM
I made Techie throw his newly powder coated cam cover away a few years ago, he was not best pleased when I refused to fit it  :sleep:
#8 vocky
Posted 09 March 2014 - 06:31 PM
grateful should suit your mood right now, that your brand new engine never had the chance to have a powder coated cam cover fitted  :ffs:
get a plastic cam cover  thumbsup
#9 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 09 March 2014 - 06:33 PM
Sean had a load of trouble on his old NA after having the cam cover powder coated the sh*t kept getting in the oil pump 😢
#10 chris_uk
why would powder coating cause the engine to fail? bits breaking up from the underneath and falling into the engine?
#11 Antnicuk
Antnicuk
  • 52 posts
Posted 09 March 2014 - 06:34 PM
thats bad news,  whats the problem with a sand blasted cover?  i assume it would be clean before coating and fitting?
#12 CHILL Gone DUTCH
Posted 09 March 2014 - 06:37 PM
Where are you based
#13 vocky
if you remove the inner steel plate you will usually find a handful of grit after sandblasting, this kills the engine pretty quickly  :mellow:
I refuse to fit powder coated cam covers for that very reason, seen it happen before  thumbsdown
Edited by vocky, 09 March 2014 - 06:37 PM.
#14 Wreelybro
Wreelybro
  • 1,641 posts
Posted 09 March 2014 - 06:39 PM
I thought I'd throughly washed it out after it was powder coated as that sand gets everywhere. Seems like I didn't. Vocky I fitted to old engine just in case so looks like I'll be hand sanding another cover for new engine.
#15 vocky
Posted 09 March 2014 - 06:41 PM
open the cam cover up (drill or grind off the rivets) and have a look inside  thumbsup
#16 The Batman
Posted 09 March 2014 - 06:46 PM
Instead of getting then to sand blast it , get them sand it by hand and then powder coat it That's what my powder coated does
Edited by The Batman, 09 March 2014 - 06:46 PM.
#17 Wreelybro
Wreelybro
  • 1,641 posts
Yup was going to do that Vocky I'm assuming once done its useless.
#18 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 09 March 2014 - 06:51 PM
Mine was sand blasted but use a gallon of petrol to clean it Made some special brandy with it after it :-)
#19 robin
robin
  • 3,810 posts
Posted 09 March 2014 - 06:53 PM
was just thinking same shirly a really good clean with petrol would of been good enough or is there hidden bits under metal tray?
#20 CHILL Gone DUTCH
Posted 09 March 2014 - 06:54 PM
Are you putting the harrop on and Dutch software at the same time as engine change?? You are a long way but if your desperate I can help Ps where is " your butt"
Also tagged with one or more of these keywords: engine, blown
