Yup, 68mm TB. Got a spare coil pack too.
Crankshaft Sensor Re-Learn / Cold Start Problem
#21
Posted 08 August 2014 - 02:09 PM
#22
Posted 08 August 2014 - 04:46 PM
#23
Posted 08 August 2014 - 07:54 PM
logging the TB idling should tell you straight away if it's different.
Also make sure you load back the last map before Peters tweaking or send him the latest if you've done some mapping since and have him set it back to normal.
#24
Posted 11 August 2014 - 07:40 PM
are your wire changes crimped or soldered?
Dunno, whatever Vocky did
the pins are simply removed and repositioned in the plug
Only the injectors, map and fuel tank vent valve are lengthened.
With regards to the problem, have you tried another map (or TMAP) sensor ?
The map (TMAP) and the tb are closely linked in the ecu map
#25
Posted 11 August 2014 - 08:45 PM
had the problem when I first swapped and that was with a standard CS style setup (map sensor)
Still there after moving to TMAP
#26
Posted 12 August 2014 - 07:07 AM
Awesome, is the TB a spare? (IE could I keep it for a week to try a handful of cold starts?)
Its not but I'm sure I could cope for a week.
#27
Posted 19 August 2014 - 09:29 PM
#28
Posted 19 August 2014 - 09:49 PM
#29
Posted 20 August 2014 - 07:11 AM
Sorry not had a chance to get any swapping out done and wrapping stuff up at work this week as I go on leave next week. One more to join us with probs though, Pete-r PM'd me to say he is getting exactly the same prob.
but interestingly it was fine on the base map
#30
Posted 20 August 2014 - 08:49 AM
#31
Posted 20 August 2014 - 08:56 AM
I should be around this weekend if you need to try some bits out.
#32
Posted 20 August 2014 - 09:02 AM
I'm in Majorca this weekend I'm afraid. 30Th any good for you? Unless your going to the Stafford Runway show on the 31st by any chance? http://www.vx220.org...car-show/page-3 Would be afternoon as I don't land until 1am that morning!I should be around this weekend if you need to try some bits out.
#33
Posted 20 August 2014 - 09:05 AM
I'm afraid I can't say. I'm awaiting orders!
#34
Edited by pete-r, 20 August 2014 - 09:07 AM.
#35
Posted 20 August 2014 - 09:37 AM
Ok will PM you when on that sat and see if either day is good for you if that's ok?I'm afraid I can't say. I'm awaiting orders!
#36
Posted 20 August 2014 - 09:47 AM
Fine by me
#37
Posted 20 August 2014 - 10:59 AM
Edited by pete-r, 20 August 2014 - 11:02 AM.
#38
Posted 20 August 2014 - 11:04 AM
#39
Posted 20 August 2014 - 11:07 AM
Second video is set to private.
When was the fuel filter last changed?
#40
Posted 20 August 2014 - 11:17 AM
Edited by pete-r, 20 August 2014 - 11:20 AM.
