Crankshaft Sensor Re-Learn / Cold Start Problem
158 replies to this topic
#101 pete-r
pete-r
  • 2,771 posts
Posted 21 August 2014 - 09:13 PM
If it's just piping, we can asume the tmap part is setup correctly.
It looks like a 90deg barb connector.
#102 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 21 August 2014 - 09:39 PM
Ok so to be clear Bargi = butterfly more open than normal Chris P Duck = butterfly more closed than normal Pete-r = butterfly more closed than normal I don't have any way of measuring the fuel pressure I'm afraid Pete. When I change the injectors earlier there was no squirt of fuel when I depressurised which was about 10 mins after it ran. But it did hiss so there was pressure and there was fuel in the rail when I removed it. I don't know if this is normal however.
#103 Exmantaa
Posted 21 August 2014 - 09:45 PM
Nope, no Saab components here. O ring retrieved, gasket cut, manifold back on, SC back on (better but still not 100% convinced as I can still see the green gasket on the bypass part) VXR injectors in the fuel rail. Just need some VXR injector wiring plugs now, any suggestions where I can get some from?
Did you put some (light coat) silic. gasket stuff around the modified PCV hole? Otherwise it might leak there...
#104 pete-r
pete-r
  • 2,771 posts
Posted 21 August 2014 - 09:50 PM
I'm not sure that's right, Peter and my local lotus specialist told me that even hours after the engine is stopped there should be fuel coming out of there. Mine is dry within moments of turn-off. Also check the valve when primed, there should be fuel in that pipe but I get nothing, so until that's fixed there's little point me looking further. Might save you messing with more complex things if it's something simple. Did you have your pump replaced during the SC work like I did?
Edited by pete-r, 21 August 2014 - 09:55 PM.
#105 CHILL Gone DUTCH
Posted 21 August 2014 - 09:56 PM
http://www.speedster...ings/index.html
here is a diagram of fuel system
#106 pete-r
pete-r
  • 2,771 posts
Posted 21 August 2014 - 10:06 PM
Nice one Chris. It's pretty obvious then, that I should have fuel flying out of the valve when the ignition is on if the pump is working and there's no leaks, but I get nothing at all! I think I need to sort that before looking at the ecu, tb and gaskets and other stuff. Do you agree?
#107 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 21 August 2014 - 10:09 PM
Yep for a Walbro 255. Can anyone confirm that fuel should squirt after priming and after turning off? Be useful to know for certain what is normal before we assume this is the problem. I certainly can't see how this could be linked to the butterfly position?
No :-(
#108 CHILL Gone DUTCH
Have you tried the valve with engine running ? I'm going to investigate mine in the morning as it's a little late now Will let you know what I find Tomoz
#109 CHILL Gone DUTCH
Posted 21 August 2014 - 10:12 PM
When I tried it for peter the other day I only got a hiss and a small amount of fuel ( next to nothing ) Just wondering if the pressure ( and pump ) is also linked to the injectors opening and closing
#110 pete-r
pete-r
  • 2,771 posts
Posted 21 August 2014 - 10:16 PM
It has to have fuel in the feeder pipe, and under pressure at that, when priming. That's the point of the pump priming it's pushing a stream of fuel up to the rail isn't it? So whether it's a dribble, or a jet you should have something but mine is dry so either no prime or the pressure it negligible. With mine, on prime it's just air, when running fuel flows out, and turned off it's air after just a few moments.
#111 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 21 August 2014 - 10:19 PM
Lack of fuel is certainly what it feels like when I try to start it. Just can't work out how that would lead to a more closed TB Or how it would be ok on the CS map would be ok (unless we' re assuming our prob is different to Bargi's?)
#112 CHILL Gone DUTCH
Posted 21 August 2014 - 10:20 PM
Can you get someone to turn ignition on while your ( priming ) while your pushing the nipple But I am thinking you could be right here peter But I'm no expert so hopefully there will be someone along shortly to give a definite answer
#113 pete-r
pete-r
  • 2,771 posts
Less fuel = less air to prevent running lean maybe? So close the throttle? Or there's an air leak adding to the air mix? I think definitely get fuel up to the rail is the first step before you start swapping injectors. How it works on the CS map I don't know, did you change the pump at a different time to the map?
Edited by pete-r, 21 August 2014 - 10:22 PM.
#114 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 21 August 2014 - 10:31 PM
I've never run a CS map. That was Bargi
Recently switched to the Dutch ECU and finding cold starting takes a good 3-4 seconds for the engine to catch. Swapping back to the CS mapped ECU it kicks over without issue.
But as before, we may have different problems
#115 pete-r
pete-r
  • 2,771 posts
Posted 21 August 2014 - 10:36 PM
That's true. Either way there needs to be fuel in that pipe and coming out of the valve at pressure so check that tomorrow. Bargi seems to have something a little more in depth maybe? I was told some of the CS sensors are deactivated so maybe something to bear in mind.
#116 smiley
Posted 21 August 2014 - 10:42 PM
When i did my walbro conversion i noticed very limited space in the pump housing, and had to twist my walbro in a specific way in order for the flexi piping not to scrape any other parts.
At this point i would start thinking about pulling the pump housing out and inspect it.
#117 CHILL Gone DUTCH
Posted 21 August 2014 - 11:04 PM
Just a quick question to chrisPduck did you check the air dump butterfly was fully closed when you took the charger off??
#118 CHILL Gone DUTCH
Posted 21 August 2014 - 11:07 PM
If this is not closed it could be stopping the fuel regulator from working
#119 Exmantaa
Posted 21 August 2014 - 11:12 PM
Are we talking about a replaced in-tank Walbr0 fuelpump? I remember one that had a split hose in the pump unit and almost no fuelpressure due to that. Siomply buy/borrow a pressure tester and check the rail pressure..
#120 smiley
Posted 21 August 2014 - 11:24 PM
He had that twice. :mellow:  (if we're talking about the yelllow winged one)
