Z22Se Engine Liners
#41
Posted 10 April 2014 - 10:08 AM
#42
#43
Posted 10 April 2014 - 10:19 AM
My injector leaking is because of this so I've spoke to Peter and he says use a couple of washers and raise it buy 2mm, I take its the same thing as the raiser blocks? Do you know where the raiser blocks are for sale so I can buy a set?
You have a boost leak passed the lower o-ring seal of the 60lb's? Do you have the grey inserts/adapters fitted with the rail raiser blocks? That should cure this definately. I think the 60's are a tiny bit taller than the original injectors and therefore may stick too far into the head with possible leakage. Might help to simply raise them a bit by fitting some washers under the rail mountiings. (Maybe elongate the mounting holes for better fitment as the injectors are under an angle.)I think the reason I was slower due to my injector leaking as it did feel slow compered to power runs I was doing.
The grey injector mounts/inserts are combined with rail raiser blocks. Fitted like that on the older B207/ Z20NET engines and I saw them also fitted on a Vectra Z22SE engine.
#44
Posted 10 April 2014 - 10:35 AM
Had a quick look in the OBD manual, but cannot find any gearbox input. So not sure how OBD calculates internally.
Maybe it uses road speed (ABS signal) vs rpm signal to work things out, but then why does it then need the tire circumference.
Peter can help you out here, but I know the Z22 ecu needs to have the right gearbox settings to work properly.
#45
Posted 10 April 2014 - 10:43 AM
because you could have 10" wheels or 60" wheels and the ABS pulses would vary substantially for the same road speed and engine speed.
What he REALLY should do is the radius from the ground to the centre of the hub as tyre size is WRONG due to tyres not staying at full size when installed on a car.
#46
Posted 10 April 2014 - 10:51 AM
Ah yeah, off course. The ABS pulses would only register hub rpms... .
#47
Posted 10 April 2014 - 10:59 AM
the 4.17 gearbox is great for below 250 bhp, okay between 250 and 300bhp, but after 300 it's probably not required
Edited by vocky, 10 April 2014 - 10:59 AM.
#48
Well, it's looking better again for your power measurements...
I'm still amazed at your low-ish inlet temps and would love to see this thing on some rollers to see what is what.
#49
Posted 10 April 2014 - 11:03 AM
That's all well documented in the OBD Tuner manual, together with a decent method of measuring the effective diameter: mark the tyre and the road where it hits the road and move the car forward (or backward when so inclined) until the mark on the tyre is closest to the road again. Measure distance to the first mark on the road. Divide by pi. Done, with reasonable accuracy
#50
Posted 10 April 2014 - 11:06 AM
Thats better than initially suggested then
I'm not about to read the manual for something I cant/dont use
#51
Posted 10 April 2014 - 11:38 AM
#52
Posted 10 April 2014 - 11:57 AM
#53
Wat are your MAP/Boost readings during the full power runs?
We fitted an 80mm (3.15) pulley on the Harrop to keep the temps down during track use, but still see close to 90°C inlet temps... Water injection to the resque!
And looking to that graph; the power drop at max rpm is quite sudden and looks a bit similar to Chill's. Was an ignition timing issue:
http://www.vx220.org...54#entry1676905
(Can you update your build thread with latest engine specs and results? Spend some time searching to what cams you have fitted in this.)
Edited by Exmantaa, 10 April 2014 - 11:59 AM.
#54
Posted 10 April 2014 - 12:19 PM
#55
Posted 10 April 2014 - 12:27 PM
#56
Posted 10 April 2014 - 12:32 PM
#57
Posted 10 April 2014 - 12:34 PM
#58
Posted 10 April 2014 - 12:36 PM
Come on dude don't be like thatGet in on a set off rollers and do the Dutch power measurement on the same run, Then all the doubters might give the software a chance Every single run I have done has been shot down from someone, I have never said it was accurate to someone's else RR but it's my measurement and in control of it. I would love to see RR calibration on the day of the run to and also would like to no where the RR sensors are put compared with where they should be put
#59
Posted 10 April 2014 - 12:37 PM
#60
Posted 10 April 2014 - 12:39 PM
