Pcv And Cam Cover Breather Options
Posted 12 April 2014 - 09:13 AM
Posted 12 April 2014 - 09:18 AM
Posted 12 April 2014 - 09:20 AM
Posted 12 April 2014 - 09:22 AM
Posted 12 April 2014 - 09:23 AM
Posted 12 April 2014 - 09:27 AM
Posted 12 April 2014 - 09:29 AM
Posted 12 April 2014 - 09:31 AM
For reference
original design
Excess gas and oil vapour is vented from the port between the inlet ports on the cylinder head. The vapour is mixed with the fresh air in the inlet manifold and burnt off during normal combustion.
Fresh air is pulled in from the cam cover which connects to to the intake pipe after the air filter to ensure the fresh air is filtered.
During full throttle applications, the PCV vent closes (there is too much pressure in the manifold and it will actually pressurise the crankcase). This effectively reverses the flow and some gas/vapour will come out of the cam cover
CS modification
The exhaust vent into the inlet manifold is blocked. This results in just one vent to atmosphere (cam cover) as there is now air trying to flow both out and in through the same hole 'bumping' happens, where volumes of oil are ejected. It's exactly the same as holding a full bottle upside down and letting the liquid drain out - it gluts/bumps as it lets liquid out and air in. This results in higher oil loss.
OBD tuner implementation
This is exactly the same as the original implementation of the PCV, however the cars typically have higher rev limits which means more time with the PCV vent closed. The implication of this is more time using the cam cover for both venting and pulling in fresh air. Not a problem when an NA, but if this is directly connected to the inlet manifold when supercharged there will be oil pulled into the laminiovas. Place a catch tank or oil filter in line, or use a small separate air filter.
So Chris, the reason your car behaves like the PCV is blocked is because you've got a high rev limit, and at high revs the PCV is blocked.
Edited by fezzasus, 12 April 2014 - 09:33 AM.
Posted 12 April 2014 - 09:32 AM
Edited by haggi961, 12 April 2014 - 09:32 AM.
Posted 12 April 2014 - 09:36 AM
Same as that.I've never had a problem with my dipstick coming out and mines been blocked for years, I've also never got any oil build up out of my cam cover breather so I'm still sort of going the blocked route.
But the Yanquis do complain that they have dipstick ejection issues on the LSJ's and increase the size of all of the external breather systems on the higher powered cars. If the Z22SE and B207 cam covers weren't such a pain with the riveted baffle plate, it would make more sense to increase the size of the breather vent to -10 fittings like some of them have. Would also make sense to put the fitting on the "high" side of the B207 cam cover, like the Z22SEI agree I think the dipstick coming out was a coincidence/fitting mistake.
Edited by techieboy, 12 April 2014 - 09:38 AM.
Posted 12 April 2014 - 09:37 AM
Posted 12 April 2014 - 09:38 AM
Posted 12 April 2014 - 09:39 AM
Posted 12 April 2014 - 10:00 AM
Is there anything in the LSJ build book about it?
You could just put another vent in, however working out where might be an issue. I've seen someone who drilled an oil filler cap to put a wider bore vent in there. Might be the best option to test if it works.
Posted 12 April 2014 - 10:02 AM
Posted 12 April 2014 - 10:06 AM
I've got a vented filler cap from the States in the garage. I had a look when I first got it and don't think it will fit with the standard engine cover, once the AN hose and fittings are connected up as it's so tall - obviously not a problem on the Cobalt and the multitude of Chevy cars that the cap appears to fit. Sticky modified his OEM filler cap and attached an extra breather hose to it.I've seen someone who drilled an oil filler cap to put a wider bore vent in there. Might be the best option to test if it works.
Posted 12 April 2014 - 10:13 AM
Posted 12 April 2014 - 10:30 AM
Posted 12 April 2014 - 10:36 AM
I was thinking more like a vent lower down similar to the gearbox breather mod so if any oil was swept up it could drain back down
I would try the vented oil filler cap before doing anything more drastic. It's effectively non-destructive as you just replace the cap.
Only other place I can think is the Turbo drain channel which was blocked up, however that's almost too low down. I would imagine a lot of oil will be pushed out from the sump.
Posted 12 April 2014 - 10:39 AM
