Dutch software has nothing to do with the mechanical state of your engine/head/PCV system...
Pcv And Cam Cover Breather Options
#61
Posted 25 April 2014 - 09:19 PM
#62
Posted 25 April 2014 - 09:32 PM
#63
Posted 25 April 2014 - 09:43 PM
#64
Posted 25 April 2014 - 09:46 PM
#65
Posted 25 April 2014 - 09:54 PM
#66
Posted 25 April 2014 - 10:00 PM
#67
Posted 25 April 2014 - 10:02 PM
#68
Posted 25 April 2014 - 10:15 PM
#69
Posted 25 April 2014 - 10:31 PM
It seems to as I had no problems when on the CS software for the past 3 years.
The CS map did not support the PCV to be open, so it was shut for 3 years.
With Dutch, you choose weather to use the PCV or not.
The technical consequences of actually using the PVC is another thing, as it's relativily new, so some R&D/trial and error may need to be done to see how it behaves.
#70
Posted 25 April 2014 - 10:49 PM
#71
Posted 25 April 2014 - 10:55 PM
I hear you.
I am torn apart between using it as designed, as from the US i hear no complaints from our lsj cousins, and putting in an decent catch tank that can seperate oil and water.
#72
Posted 26 April 2014 - 09:01 AM
#73
Posted 26 April 2014 - 09:25 AM
alloy putty is probably better, but you need to trim the cam cover gasket so the oil doesn't build up in the channel above it - this is what causes the oil build up in the first place
#74
Posted 26 April 2014 - 09:52 AM
I'm thinking of this http://www.ebay.co.uk/itm/331138226464I hear you. I am torn apart between using it as designed, as from the US i hear no complaints from our lsj cousins, and putting in an decent catch tank that can seperate oil and water.
#75
Posted 26 April 2014 - 09:54 AM
#76
Posted 26 April 2014 - 09:55 AM
Edited by haggi961, 26 April 2014 - 09:56 AM.
#77
Posted 26 April 2014 - 09:56 AM
#78
Posted 26 April 2014 - 10:59 AM
