Pcv And Cam Cover Breather Options
#81
Posted 26 April 2014 - 11:57 AM
#82
Posted 26 April 2014 - 12:32 PM
#83
Posted 26 April 2014 - 12:35 PM
#84
Posted 05 May 2014 - 12:30 PM
I decided a while ago to recreate the factory PCV on my car.
Because the inlet manifold phenolic spacer had blanked off the original B207 cylinder head breather hole I drilled and tapped the cam cover instead and fitted a small brass take off with an internal 1.5mm hole. I then used some 3mm silicone hose to connect that to a replacement brake servo one way valve - with a small take off, astra / vectra etc.
Next job was to badger Joe to get me an LSJ cam cover breather hose
This was a simple job to fit as it's OEM, so two bolts onto the cylinder head, a M6 stud and nut on the cam cover for the metal support and the hose fitted straight into my throttle bodies air filter, it will need a little tweak but I can report after two hours blasting about today not a single drop of oil or oil mist was present in the air filter housing
Edited by vocky, 05 May 2014 - 12:32 PM.
#85
Posted 05 May 2014 - 12:34 PM
crappy yellow squiggles = LSJ breather
crappy red squiggles = vacuum supply to cam cover
#86
Posted 05 May 2014 - 02:08 PM
#87
Posted 05 May 2014 - 03:03 PM
Don't be giving mine away.
If you do, the bonnet gets it
#88
Posted 05 May 2014 - 03:16 PM
#89
Posted 10 June 2014 - 12:10 PM
#90
Posted 10 June 2014 - 12:20 PM
Is your internal PCV channel (head <> manifold open or closed off?
#91
Posted 10 June 2014 - 12:22 PM
#92
Posted 10 June 2014 - 12:41 PM
OK, then I would run a hose from the cam cover to before the TB, to keep normal PCV working. But maybe better to stick a decent catch can in between the cam cover hose. Preferably with a drain back to the sump, but I think you then also need a one-way valve in the drain line.
#93
Posted 10 June 2014 - 12:57 PM
#94
Posted 10 June 2014 - 01:06 PM
The tank shouldn't be pressurised if its connected into the inlet pre-throttle as that just leads to the filter.
#95
Posted 10 June 2014 - 01:10 PM
But under full throttle applications I would get a vacuum which would/ should pressurise the tank And pull from cam coverThe tank shouldn't be pressurised if its connected into the inlet pre-throttle as that just leads to the filter.
Edited by CHILL Gone DUTCH, 10 June 2014 - 01:10 PM.
#96
Posted 10 June 2014 - 01:24 PM
Ah yes, it will be under vacuum at some points. Should be fine as long as its not a coke can.
#98
Posted 10 June 2014 - 01:40 PM
#99
Posted 10 June 2014 - 01:42 PM
#100
Posted 10 June 2014 - 01:44 PM
Edited by CHILL Gone DUTCH, 10 June 2014 - 01:44 PM.
