No That was with cam cover open to atmosphere near wheel arch via pipeWTF?!?This was one track day there was also minor dripping between sessions
You're running a diesel??
Edited by CHILL Gone DUTCH, 10 June 2014 - 02:55 PM.
Posted 10 June 2014 - 02:55 PM
Posted 10 June 2014 - 02:56 PM
That picture makes me want to chunder, whenever I see it.
I've never seen any other VX do that, to that degree. Not even when adding gearbox fluid to the mix as well.
Posted 10 June 2014 - 02:57 PM
probably only vx with standard under tray onThat picture makes me want to chunder, whenever I see it.
Posted 10 June 2014 - 05:48 PM
Edited by oakmere, 10 June 2014 - 05:48 PM.
Posted 11 June 2014 - 07:06 AM
Chill I had one of those cans and there is nothing to separate the air flow inside. So I would add some sort of baffle plate then fill with the above wire scourers available from supermarket. Even my lowly NA suffers from oil being dragged through the PVC and most std cars have oil in the inlet manifolds. I am pretty sure I have too much oil in mine as it takes 6.5L on an oil change to get to the dip stick top mark?
The can on mine (same as yours) catches very little and most oil mist comes straight out the breather side of it. If you're connecting back in to your inlet (pre throttle) you'll end up with fouled laminova VERY qiuickly without some sort of effective separator.
Posted 11 June 2014 - 08:25 AM
Posted 11 June 2014 - 08:42 AM
Is your internal PCV channel (head <> manifold open or closed off?
Open But it's high loads that gives me the problem ( track use )
So you have an open PCV valve between head and manifold, and have the cam cover pipe open to atmosphere near wheel arch. So I do hope you have an air filter on that pipe, otherwise your engine is ingesting unfiltered air during normal cruise...
Posted 11 June 2014 - 09:05 AM
Posted 11 June 2014 - 11:38 AM
Posted 11 June 2014 - 11:50 AM
Posted 11 June 2014 - 12:13 PM
Fine as long as its filtered fresh air IMO.
Posted 11 June 2014 - 12:14 PM
Posted 11 June 2014 - 01:57 PM
Most definitely. On the Z20LET engine, the OEM crank relief pipe rises up from a very similar height as the turbo oil reutrn hole. All you need to do is create/atach a vertical pipe (say 12 inches approx)from the turbo oil return hole in the side of the block and fit either a catch tank on the top of the pipe or just a simple £2 breather gauze.Could we also vent from the turbo return ??
Posted 23 June 2014 - 10:04 AM
Posted 23 June 2014 - 08:42 PM
Posted 24 June 2014 - 02:55 PM
Posted 09 July 2014 - 05:44 PM
Posted 09 July 2014 - 05:58 PM
Edited by CHILL Gone DUTCH, 09 July 2014 - 05:59 PM.
Posted 09 July 2014 - 06:30 PM
Edited by oakmere, 09 July 2014 - 06:31 PM.
