Pcv And Cam Cover Breather Options
201 replies to this topic
#141 chris_uk
Posted 10 July 2014 - 08:10 AM
I dint know why you just dont do what i have done.. All my intake is as clean as can be and i dont get oil everywhere.
#142 smiley
Posted 10 July 2014 - 08:16 AM
Is your PCV open chris?
#143 vocky
Posted 10 July 2014 - 12:17 PM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]If you have [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:14px;]a new Saab engine it might be an idea to use the PCV valve from the new Saab inlet manifold in the SC inlet manifold, as they might need replacing due to old age.[/color]
Edited by vocky, 10 July 2014 - 12:18 PM.
#144 chris_uk
Posted 10 July 2014 - 12:19 PM
Nope, blocked off with the phelonic spacer.
#145 CHILL Gone DUTCH
Posted 10 July 2014 - 01:06 PM
[color=rgb(40,40,40);][font="helvetica;"]If you have [/color][/font][color=rgb(40,40,40);][font="helvetica;"]a new Saab engine it might be an idea to use the PCV valve from the new Saab inlet manifold in the SC inlet manifold, as they might need replacing due to old age.[/color][/font]
I will be changing mine in winter as a precaution
#146 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 02 September 2014 - 07:14 PM
Well had car apart a few weeks back and opened my pcv valve up ,my car used to breath quite allot through the rocker cover pipe but since doing it nothing not a spot of oil etc so seems to be working on my car :-)
#147 CHILL Gone DUTCH
Posted 02 September 2014 - 07:20 PM
Good stuff lee what did you do with the pipe of the rocker cover ?? Are you going snetterton
#148 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 02 September 2014 - 07:33 PM
Just breathing to atmosphere as it was but it's as dry as a bone now. :-). Snetterton yes I will book it Friday pay day lol
#149 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 02 September 2014 - 08:08 PM
How many miles have you done since doing it mate and gave you checked the inlet manifold for oil. Still not sure what to do with mine yet.
#150 CHILL Gone DUTCH
Posted 02 September 2014 - 08:15 PM
Going to swap my original one from manifold for the Saab one
I've not looked at it yet but how does it come out
Is it threaded or pressed in ?
#151 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 02 September 2014 - 08:36 PM
Done Bedford track day and a few road miles havnt checked inlet but after snetterton I will give it a strip down and inspect .
#152 CHILL Gone DUTCH
Posted 02 September 2014 - 08:50 PM
For everyone's info the Pcv valve just pushes out There only held in by rubber washer
#153 fezzasus
Posted 03 September 2014 - 08:43 AM
http://vsetrack.com/...l_separator.htm
#154 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,121 posts
Posted 03 September 2014 - 09:21 AM
I will be very interested to see what you find Lee. How is your oil consumption now??
#155 Winstar
Winstar
  • 4,264 posts
Posted 03 September 2014 - 09:23 AM
If that's supposed to be a cyclonic separator the green arrows on the website shows it plumbed the wrong way around?
#156 techieboy
Posted 03 September 2014 - 09:28 AM
I have one of those BMW separators here and a bigger one that is basically two of them in series by the look of it.
#157 fezzasus
Posted 03 September 2014 - 09:42 AM
I'll give one a go when I finally get my engine sorted. Next step up are powered separators used in CV aplications
#158 cicastol
cicastol
  • 423 posts
Posted 19 September 2014 - 02:58 PM
Yes it's a cyclonic separator clearly plumbed in the wrong way !! ROTFL
Edited by cicastol, 19 September 2014 - 03:06 PM.
#159 siztenboots
Posted 19 September 2014 - 03:53 PM
will test the bmw filter asap
#160 smiley
Posted 05 October 2014 - 03:25 PM
Saab B207 stage 3 atm.
My pcv is open, with a catchtank in between.
It has now done at least 1000 miles of which most spent on track.
The catchtank is empty.
The air inlet has a minimum of oil smear visible.
Engine has no oil consumption.
So mine is staying open.
:tt:
Edited by smiley, 05 October 2014 - 03:26 PM.
