Pcv And Cam Cover Breather Options
#161
Posted 05 October 2014 - 03:29 PM
#162
Posted 05 October 2014 - 03:39 PM
Difficult to say, as in my case it does not seem to be actually doing anything atm.
It's still staying in there though
#163
Posted 05 October 2014 - 03:47 PM
👍Difficult to say, as in my case it does not seem to be actually doing anything atm. It's still staying in there though
#164
Posted 12 October 2014 - 08:19 PM
#165
Posted 13 October 2014 - 08:14 AM
#166
Posted 13 October 2014 - 02:21 PM
#167
Posted 13 October 2014 - 02:31 PM
#168
Posted 17 October 2014 - 11:42 AM
Counter to running thicker viscosities is that the engine was never designed for it, so you'll unduly stress the oil pump and associated chains/belts
#169
Posted 17 October 2014 - 11:50 AM
#170
Posted 17 October 2014 - 01:49 PM
#171
Posted 09 January 2015 - 05:41 PM
#172
Posted 09 January 2015 - 06:36 PM
#173
Posted 09 January 2015 - 06:38 PM
#174
Posted 29 July 2015 - 06:57 AM
Well I now have a saab engine (deep joy) and my car is as covered as Chills was in those pictures.
What is the final conclusion from all this as I cant see how sticking the breather pipe into the inlet of my sc is going to do any good at all.
Do I need to do that and fit some sort of dodgy catch tank in as well. All seems a bit heath robinson to me.
Martin S
#175
Posted 29 July 2015 - 07:15 AM
Why not fit a separator with a return pipe? Most catch cans are literally just a can, a proper separator will make a big difference.
#176
Posted 29 July 2015 - 07:40 AM
#177
Posted 29 July 2015 - 07:59 AM
With it open to atmosphere and your inlet valve blocked of means you can't replace the fresh air that is needed in the crank area?Venting to atmosphere is always the best solution. The only reason modern cars vent back into the inlet is due to legal/emissions restrictions, however this conflict with good combustion because feeding oxygen starved oily air into the inlet track is obviously a bad thing to do.
#178
Posted 29 July 2015 - 08:04 AM
If you run it vented (like I do as well, hose from the cover to a catchcan with a small breather), you gave an open line from cranckcase to atmosphere. Ait can run both ways depending on pressure.
#179
Posted 29 July 2015 - 08:22 AM
My interim solution (high tech it isn't) is going to be sticking the pipe in a big bottle mounted in the engine area just to see how much is actually blowing out. Am only going up to 5000 revs max at them mo, will it get worse at higher revs?
Martin S
#180
Posted 29 July 2015 - 08:57 AM
This is what I have too - I don't get any crud out the back of the car but do collect a lot of stinky/oily water in the catch tank which I assume would otherwise have sprayed all over the back of the car.
