Removing The Fuel Pump Housing
16 replies to this topic
#1 smiley
Posted 12 April 2014 - 08:26 PM
From vocky's gui:
remove the circlip. I asume by pressing together the red arows.
That bendy little arch between the red arrows will not break?
Second:
"you then need to remove the plug from the pump housing, then remove the two fuel pipes, these have spring clips holding the pipes onto the housing, press the upper and lower clips to slide the fuel pipes off"
Where do i press exactly to make the clips release pressure?
#2 techieboy
Posted 12 April 2014 - 09:14 PM
Yep, compress the circlip using the two holes and it'll pop out from underneath the lip of the tank. The plastic bit should be fine and it's only there to make sure the pump goes back in the right orientation.
Can't really remember what I did for the Quick Disconnects, think I just squeezed the two tabs that stick out from the main black part of the plug and pulled it off the outlet/inlet. Was very easy but I know some have had problems.
#3 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 12 April 2014 - 09:37 PM
Just as Techie says. Circlip is easy, I had a battle with one of the fuel pipes but they do come off.
#4 JG
JG
  • 13,612 posts
Posted 12 April 2014 - 09:52 PM
and refitting them to a PA tank is the second worse job on a vx after the exhaust mesh replacement
#5 smiley
Posted 12 April 2014 - 10:12 PM
At the blue arrows, or the red one?
#6 CHILL Gone DUTCH
Posted 13 April 2014 - 01:42 AM
I think it's the grey bits which want squeezing outside the black housing
#7 CHILL Gone DUTCH
Posted 13 April 2014 - 01:43 AM
Then pull the black bit with grey bits compressed It's a PITA
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 13 April 2014 - 09:09 AM
I have always pushed in the bits arrowed red but then I have had a bit of a job in the past.
Edited by Mike (Cliffie), 13 April 2014 - 09:09 AM.
#9 smiley
Posted 13 April 2014 - 12:10 PM
It's a PITA
Spot on.
It came off very easily in my case.
Indeed squeeze on the blue plastic ends at the red arrow part, which will then push down blue arrow blue plastic part locking mechanism, unlocking the black part. Then pull the black part back.
Now for the return line, which seems to look different.
Open to suggestions. :)
edit, how to release what is cathing on to the red arrow latch.
Edited by smiley, 13 April 2014 - 12:20 PM.
#10 CHILL Gone DUTCH
Posted 13 April 2014 - 12:50 PM
I think the blue clip should still be on the housing
#11 smiley
Posted 13 April 2014 - 01:15 PM
The last pic is from vocky's topic.
Any idea what to press/squeeze/impregnate for the return line? (and leave the blue plastic in place)
#12 CHILL Gone DUTCH
Posted 13 April 2014 - 01:19 PM
No squeezing Push blue ring towards black plastic and then move black plastic away and repeat process This is only from memory and might be wrong
#13 smiley
Posted 19 April 2014 - 05:01 PM
Well, the return line is basicly the same principle, just slightly different.
A little blue plastic thingy, that is latching on to the black plastic part.
On the right pic it's easy, just put some pressure on what you can see.
The one at the bottom side is a pit of a handfull :mellow:
In my case i could force it in by putting a thin piece of metal between the blue and black part; exactly at the point of the red arrow on the left pixie.
Now that i have done both, i can say that if you press EXACTLY on the correct places, both connectors should come off with a brease.
I have no idea if the little blue ring should have been attached to the plastic construction or not.
If it does, i can understand that squeezing it could bring the little plastic latches in, releasing the black connectors.
If your blue ring is loose like mine was, just follow above guide.
Edited by smiley, 19 April 2014 - 05:05 PM.
#14 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 27 October 2017 - 11:21 AM
Any chance you can repost the pic Stefan? chinky chinky
#15 smiley
Posted 28 October 2017 - 10:02 AM
pics restored.
After having to do it again after taking the picture, i would have to add that getting access to the pressure point on the blue clip of the return line is easier once the feed line is off, then loosening the complete pump housing, so it can twist a little, making access to the return part easier.
With the pump housing fixed in place it's much harder in that tight spot.
Edited by smiley, 28 October 2017 - 10:03 AM.
#16 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 29 October 2017 - 10:07 AM
Great, thanks Stefan chinky chinky
#17 Spitfire Engineering
  • 755 posts
Posted 29 October 2017 - 01:03 PM
Don't forget to remove both of the clips from the pump and insert then into the fuel fittings ready for refitting.
On the blue one I think the blue ring is the secondary lock, try to see if it clicks in place after fitting or better still play with it while out of the car.
