Next stumbling block in daily trials. As part of my quest to diagnose why I'm only holding 15PSI boost (when it used to be 18), I have had a look at all the hosing and it seems ok, am holding a vaccume without any issues. I've also read a handy document that Nev was kind enough to send me regarding the workings of a VX/VXR turbo and assosiated gubbins.
As such, and having yet to find the problem I'd like to fiddle with my (actuator) nuts to see if it helps as I can't help but wonder if said boost is creeping out of the wastegate.
So, If possible, I would like a little clarification as to how best to go about this. I've done a search here and read numerous threads of differing opinion, but none seem to have pictures, and what isn't 100% clear to me is what side people are talking about when they say moving the nuts up or down, or indeed having more or less thread showing.
So, to tighten the preload and increase the PSI required to open the wastegate which way do I twiddle?
From what I've read here I assume that I should consider moving the nuts closer to the end or bottom rod (fewer threads)?
I've also googled other forums (Astra etc.) and one chap said it should be adjusted like this to hold 18-20psi of boost (presuming the map is trying for it):
But that looks a little extreme to me?
Any pointers?
