As per title, anyone got any decent new or used four-pot front brakes for sale?
Cash waiting for the right 'kit'. What have you got?
G
Posted 07 May 2014 - 08:15 AM
G
Posted 07 May 2014 - 08:38 AM
Posted 07 May 2014 - 08:54 AM
Why not get a set of the MGF ones and get a local shop to mod them like JT did. Piston size is supposed to be a better match to the OEM rears.
Posted 07 May 2014 - 08:56 AM
Did nelly sell his ??
Yes.
Posted 07 May 2014 - 08:57 AM
As these are on sale, currently considering these as price seems reasonable.
http://www.seriously...ake-upgrade-kit
It is a possibility Matt.
G
Posted 07 May 2014 - 09:03 AM
Don't waste your money. It's a lot of money for very little benefit
Posted 07 May 2014 - 09:04 AM
Posted 07 May 2014 - 09:29 AM
Have a set op AP 4 pots I would consider selling
DG
Posted 07 May 2014 - 10:11 AM
I understand the 'benefits' of four pots are not more braking ability (on a car as light as ours) or even more bite - both of those can be had from a better pad and disc set up on the standard 2 pots.
Agreed, some bells and rotors with decent 2pot pads will be a far better use of money.
See above.
However I have had (admittedly minor) brake heat issues on track with the two pots in my old VXT from being out for longer than a 10-12 min session at Pembrey. Worth adding that was with new fluid, recent (and decent) pads and discs.
DG
Drop me a PM or text with details please Duncan.
G
Posted 07 May 2014 - 10:13 AM
G will ping you later - sure they are the ali belled kit, red caliper ones. Was not really looking to sell but your post and need of cash may free them off my car
DG
Posted 07 May 2014 - 10:17 AM
On sale, but still the same price as other kits; http://www.elise-sho...2-p-502321.html
DG
Ah... red?
Posted 07 May 2014 - 10:18 AM
Not if you have to pay VAT like me Tom.
The Elise shop ones are £1,500 inc VAT. The Seriously Lotus ones are £1,260 inc VAT.
G
Posted 07 May 2014 - 10:19 AM
The Ali Bells and Discs will help with heatHowever I have had (admittedly minor) brake heat issues........
Posted 07 May 2014 - 10:21 AM
Agreed, but I'll have considerably more power and be carrying more speed (in theory, thanks to set up and wheel/tyres etc) while also hoping to spend more time on track with this car than with the T.
Also, I spunked £600 on a 60L fuel tank (fitted last night) and I sit there and think if there's anything I shouldn't be skimping on then it's brakes, so if I can spend that much on something I really didn't need, then I should probably spunk a little more than that on some brakes!
And when I say minor, I mean I lost all braking force on the way into the hairpin at Pembrey - and generally I reckoned I was quite gentle on the T's brakes while on track. I suspect I'll be more aggressive in the new car.
G
Edited by Graeme Lambert, 07 May 2014 - 10:22 AM.
Posted 07 May 2014 - 10:40 AM
This is in illogical view and i start by stating that.
But i hated the VX's brakes prior to my little upgrade and now i love them. So much confidence and repeatability it totally transforms the way you drive the car.
My upgrade was;
VXR abs unit
4 Pot AP front calipers
Ferrodo 2500 pads (including recent replacement as they don't last very long ~5-6k miles) front and rear
Plans Ali Bells and 308 Reyland rotors
Stainless hoses
Motul RBS600 (or something like that) fluid, changed yearly (it comes out the colour it goes in, a bit like the oil )
Now, it may well be that only one of those would have has the same effect, i don't know. All i know is that the ham fisted, change everything approach worked brilliantly.
I started with 308 solid discs which were fine, but the improvement in steering feel on the lighter wheels and rotors is quite stark.
Posted 07 May 2014 - 11:50 AM
What pads? Sounds like they weren't up to the job.
Posted 07 May 2014 - 12:53 PM
exactly!
I have done 24H races on slicks with the std 2 pots, no issues (1 pad change at 14 Hours)
sounds like sh*t pads and disks to me.
only advantage 4 pots have is:
1) bigger pads - longer life
2) can be sped'ed for bigger/fatter disks
unless your doing endurance racing on slicks, really not worth it, just spend the money on PROPER disks and pads.
Posted 07 May 2014 - 01:00 PM
if you were looking at rotor options from PF, Alcon or Tarox , is 25.4mm the obvious choice thickness for the 2pot
likewise for ease of availability 295 ⌀ , with 12x 177.8 pcd x 6.4 ⌀ mountings
