Tee hee hee.
There is many ways to skin a cat you know.
I was something of a worst case in my VXT as I had plenty of power, pretty high weight, but low cornering speeds so the brakes got abused and i repeatedly had issues with plain disks/mid range track pads and good fluid. No braking at all boiled fluid!
Some fact and some opinion here but:-
- The first thing is to make sure your rears are doing their share of the stopping! On a standard setup use the same rear pad as fronts.
- I don't like the 2 pot calipers, the pad is tiny and MANY compounds can't cope with this sort of pressure and break down with heavy use. Sintered and full on race pads are an exception, but they all seem to wear unevenly which for me ended in the pistons sticking due to the moment generated.
- Other than this, yes the disks are the main heat-sink in the system. (Aluminium IS a better heat sink than steel by the way, by a margin!) so one way or another you need to address this in order to solve the heat issue.
I used the (cheap) 4 pots from the TF and bigger (cheap!) 308mm disks and then 50quid pads and cheap fluid was suddenly more than good enough which made for super cheap running costs. Unsprung mass - slightly worse than stock.
On the civic i've stuck with the stock 1 pots all round and these work fine (as they have a decent size pad!!) but bought new castings to allow the use of bigger disks, and I bought BETTER disks with proper vents. I have a picture somewhere. A proper disk should have more vent than metal imho!
On a VX i'm sure good disks/pads/fluid will do the job fine, but this is a lot of money at ~150quid a set of pads ~400quid a set of disks and still you are left with the stupid wedge shaped pads from calipers which look to ME to have been designed for use as rears on something.
