Need help with gearbox / drivetrain noise. (Sounds like knackered bearing (or imagine stones being spunn around in and old baked bean tin)
First a little history...
New B207 with Z22SE Crank fitted with piper stage 2 cams balancer delete, Courtenay Light Flywheel and uprated clutch.
Has been fitted to my original 92k gearbox work OK but noisy in under load and lift off.. Came the conclusion either pinion or first motion bearings where shot. So bought a replacement gearbox out of a 34k vx220 fitted and has exactly the same issue although sounded a little worse to cut long story short the same noise.
So decided to take it out and have it refurbished... (All main bearings replaced) so bunged it all back in again and guess what still have the same noise!!!
Pretty gutted to be honest..
Noise goes when clutch is dipped but is prominent is all gears under load under 2500rpm's over it gets better but does not disappear. Also hear on high rpm lift off.
So went to gearbox builder and took him out did some tested and he thinks could be down to clutch plate/flywheel. No convinced with this went to see a friend who head mechanic and worked on cars for over 20 years said could well be the clutch flywheel combo.
Anyway I'm still not convinced and hoping the great .org could help me out as I've have this engine/gearbox in and out 4 effin times now pretty much every weekend since beginning of April .
Has anyone else experienced this kind of noise and know the issue?
Also is anyone around Herts/Bed/Bucks willing to come out for test drive see if they know??
Getting so fed up with it now don't know what to do next.. Close pulling it out again and putting in standard flywheel/clutch but if still does the same it may be can of petrol and a match!!!!
Pleeeeeeeese Help me before I do something I regret!!
