Gearbox Woes!
118 replies to this topic
#21 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 07 May 2014 - 08:43 PM
If it grinds when in gear but goes when the clutch is dipped then it is release bearing/clutch assembly for the prime suspect.
The only other thing is thrust bearings but a new engine and rebuilt gearbox leads me to look elsewhere.
#22 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 07 May 2014 - 09:50 PM
Yeah I'm at a loss don't knt what to do.
#23 vocky
Posted 07 May 2014 - 10:56 PM
what about the driveshafts / cv joints ?
#24 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 05:49 AM
Don't think so sounds like cogs meshing badly but I could be wrong.
#25 FLD
Posted 08 May 2014 - 07:31 AM
This may be waaay off but its an idea that would be good to rule out.  If its a noise that disappears when you dip the clutch (ie its there under load) could it be a slight movement of the engine and its one of the moving parts grinding against something?  Might be worth just checking round the drive belt area or checking the side  engine mounts.  Whilst its unlikely its an easy one to check and rule out.
#26 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 04:39 PM
Definitely not drive belts, noise is coming from clutch/gearbox location pretty sure is something to do with the drive train. But thanks.. (Still looking for a VX'er to listen to noise, I can drive it so if anyone is around I can takea drive out. (not miles though just in case!!!)
#27 Nev
Posted 08 May 2014 - 05:43 PM
Apart from the noise, are there any other symptoms? Perhaps just driving it for a bit to see if gets worse, or is the sound so horrible that you instinctively feel like driving round like Miss Daisy ?
#28 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 05:48 PM
Apart from gear chatter on tick over due to cams and light flywheel no other issues. It is drivable but as you say driving it, it sounds horrible. (Sounds a bit like straight cut box)
#29 Kieran McC
Kieran McC
  • 3,416 posts
Posted 08 May 2014 - 06:07 PM
Sounds like the selector forks grating on gear change , With the box being rebuilt I doubt it .
#30 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 06:24 PM
I'll try and record the noise when I can find a passenger not sure how successful that will be though.
#31 rossma
rossma
  • 322 posts
Posted 08 May 2014 - 06:44 PM
Could it be an engine mount ?
#32 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 08 May 2014 - 06:48 PM
I'm around tonight if that helps. Live in Shenley.
#33 slindborg
Posted 08 May 2014 - 06:55 PM
Bring it over here :lol:
#34 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 06:56 PM
Nope not the mounts.
#35 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 07:20 PM
Was planning on bringing over to show you at some point anyway. Sticky going to have listen on Saturday first.
#36 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 08 May 2014 - 07:28 PM
I'm on his way to you Slindy. Matt can have a circular tour of herts/Essex borders!
Edited by Sticky, 08 May 2014 - 07:29 PM.
#37 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 07:32 PM
PM me you addy Stu will see how it goes.
#38 slindborg
Posted 08 May 2014 - 07:53 PM
It'll be like seeing an ex gf :( :lol:
#39 Wreelybro
Wreelybro
  • 1,641 posts
Posted 08 May 2014 - 07:59 PM
lol she's had a makeover! !
#40 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 08 May 2014 - 08:06 PM
Want me to dig out your pic with it Stu? :lol:
