so now you have the clutch and flywheel out of the car what size are the holes you drilled for the flywheel studs ?
Gearbox Woes!
#81
Posted 19 May 2014 - 04:26 PM
#82
Posted 19 May 2014 - 07:30 PM
Got to take it back to the builders first as I paid for a rebuild and think he should sort it out first. But if have no joy we can pull it apart.Facny doing some surgery on the F23 you took off Matt?
#83
Posted 19 May 2014 - 07:32 PM
I'll pop it over you can have a looky! PM me when you're about at lunch time. Also have a question about engine (Nothing Serious)so now you have the clutch and flywheel out of the car what size are the holes you drilled for the flywheel studs ?
#84
Posted 19 May 2014 - 07:33 PM
At Croft I remember hearing yours chatter a little on idle in the pit garage but true I don't remember hearing any noises while driving.Unlikely to be the fly wheel as mine is fine the only difference between op is I have a paddle clutch rather than the cs uprated clutch
#85
Posted 19 May 2014 - 08:22 PM
#86
Posted 19 May 2014 - 08:33 PM
Thanks george, I've just been to start the car there no noticeable chatter on tick over and as george says you can't hear f all when spanking itI've never heard chills chatter or vibrate. Then again you can't hear fcuk all over that horrible whine, then there's the noise of the sc . . .
#87
Posted 19 May 2014 - 08:34 PM
#88
Posted 19 May 2014 - 08:59 PM
#89
Posted 19 May 2014 - 09:06 PM
I have one with a broken casing so you've welcome to have a look at.Someone must have a 'spare' f23 that I can strip and have a pop at before looking at doing more
Edited by Sticky, 19 May 2014 - 09:06 PM.
#90
Posted 20 May 2014 - 07:02 AM
I'm not about at the moment, but all you need to do is get a M8 bolt and if it's loose in the drilled holes then thats most likely the issue.
If the clutch cover is off centre then it will cause excess vibration and thus the gearbox input shaft will make a racket.
#91
Posted 20 May 2014 - 08:33 AM
http://en.wikipedia....ng_.2F_Grinding
http://www.grandamgt...hp/t-14735.html
http://www.j-body.or...i=47351&t=47351
most awesome
http://www.fiero.nl/...TML/087296.html
Edited by slindborg, 20 May 2014 - 08:36 AM.
#92
Posted 31 August 2014 - 08:05 PM
Any news on this?
Is it the holes in the pressureplate that is to big or is it the release bearing that makes contact when it should not or is it something else?
I believe my noise has become worse during summer.
Edited by OneYet, 31 August 2014 - 08:07 PM.
#93
Posted 07 December 2014 - 07:56 AM
Hello, any news about der rattleproblem ?
#94
Posted 07 December 2014 - 08:57 AM
#95
Posted 07 December 2014 - 02:36 PM
I have done some more research about this and it seems that it happens to some when using a lightened flywheel.
Might be that the lighter wheel lets the pulses of the crank transfer into the gearbox more unfiltered.
If you look around you will for ex find a guy with a M3 having the same sound.
#96
Posted 07 December 2014 - 03:41 PM
#97
Posted 07 December 2014 - 05:07 PM
#98
Posted 07 December 2014 - 05:32 PM
#99
Posted 07 December 2014 - 05:36 PM
#100
Posted 07 December 2014 - 06:06 PM
