Gearbox Woes!
#101
Posted 07 December 2014 - 06:10 PM
#102
Posted 07 December 2014 - 06:36 PM
#103
Posted 07 December 2014 - 06:48 PM
#104
Posted 08 December 2014 - 09:17 AM
Sorry to be a pain in the butt, could you give advise on the following. A - When engine on tick over in neutral and foot off the clutch peddle can you hear the noise ? B - When engine on tick over in neutral then press the clutch peddle can you hear the noise ? C - When engine running at 2000rpm in neutral no clutch pressed can you hear the noise ? D - When engine running at 2000pm in neutral press the clutch peddle can you hear the noise ? Then B and D again but then press the clutch peddle on and off several times and does the noise come and go ? Does it get louder or quieter when doing of the above ?
For me it is No on all the above.
I get the noise as soon as I lift the throttle above 50 mph in fourth and fifth gear.
When the engine is doing the work it is quiet, when the forces is coming from the wheels I get the noise.
#105
Posted 08 December 2014 - 08:36 PM
#106
Posted 08 December 2014 - 08:45 PM
#107
Posted 09 December 2014 - 01:49 AM
Mm m I'm thinking is down to the clutch and flywheel combo atm under load ie engine power noise is far less under load from wheels is when you most hear it. Spline to clutch plate is fine and also clutch go cover. However can not been balanced this is a job over the next couple of months. Take out and balanr whole engine.Dowells are fine and input shaft and bearing have been replaced/checked. As you say may have to live with it.. Thank you for the input. If you are ever around the Milton Keynes area you are welcome for a spin to listen...
A vibrational noise is common in a number of production cars after the flywheel has been lightened.
This will be why your mechanic friends suggested this as a possible cause.
Lightening the flywheel most likely upsets the original Development Engineers calculations for crankshaft torsional dampening.
Edited by 909, 09 December 2014 - 01:50 AM.
#108
Posted 09 December 2014 - 08:29 AM
Is that the reason my guy asked for the crankshaft too when he lightened my OEM flywheel ?
#109
Posted 09 December 2014 - 08:39 AM
Not as such, but getting it all balanced together is a smart moveIs that the reason my guy asked for the crankshaft too when he lightened my OEM flywheel ?
#110
Posted 09 December 2014 - 09:19 AM
I now get a lot of clutch spring noise when coasting , I blame a couple of recent 1/2 gear launches. It could just be the friction plate springs have moved.
#111
Posted 09 December 2014 - 03:23 PM
Had a nice natter with VX220BOB last night great guy and thanks for the advise, we didn't acutally come to any conclusions but is definatly pointing towards light flywheel and gear harmonics. My Clutch springs are tights but I am able to twist them a few degrees in the plate casing. I'm assuming ths is normal..
#112
Posted 09 December 2014 - 03:38 PM
#113
Posted 11 December 2014 - 11:25 AM
#114
Posted 11 December 2014 - 02:50 PM
#115
Posted 11 December 2014 - 07:41 PM
#116
Posted 11 December 2014 - 10:01 PM
#117
Posted 22 December 2014 - 01:04 PM
Let me know how you get on George sounds like we're getting closer to an answer.
Picked my box up today and there wasn't a lot wrong with it. I took my clutch with me and the guy took one look at it and said there's your problem. The very edge of the springs are shiny and have the odd tiny chip where the springs have turned. They aren't particularly loose and to my untrained eye I was happy to reuse the clutch. Ill be ordering a new clutch plate, pressure plate and release bearing but not sure what to buy yet. I fitted the Helix 4 paddle clutch roughly 8k miles ago so not brilliant at £640 a pop with the bearing.
I know yours was a new clutch Matty but when you were doing your weekly gearbox removal did you try just changing the clutch plate back to the original? Ill let you know if my noise is gone when I get it all back together.
#118
Posted 23 May 2015 - 07:39 PM
#119
Posted 23 May 2015 - 07:44 PM
Mine still makes the same noise after gearbox rebuild, complete new clutch and slave cylinder. That was an expensive exercise! Must be the lightweight p*ss poor balanced flywheel on my car.
