Reinforced Subframe Year?
10 replies to this topic
#1 Exmantaa
Posted 08 May 2014 - 09:41 AM
From what year was the reinforced VXT subframe introduced? And what build # NA's have this fitted too?
Is it visible where it's strengthened, or exact same design manufactured with thicker steel?
(My old NA frame is cracked & welded, so it's time to look for something better...)
#2 fezzasus
Posted 08 May 2014 - 10:09 AM
I honestly didn't know there were different subframes, I will be watching this with interest. I guess the obvious question is how much the Europa subframe differs from the VX220 one.
#3 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 08 May 2014 - 10:35 AM
I noticed my subframe was different to the NA, the downward pointing legs at the back have a gusset left in on mine where the NA was cut tighter into the corners. It was seeing this that stopped me from reinforcing it as I susspected cracked subframes were the ones without the gusset, mine showed no signs of stress.
Edited by Crabash, 08 May 2014 - 10:35 AM.
#4 Exmantaa
Posted 08 May 2014 - 10:47 AM
Any pics of this somewhere?
That sounds as the affected area which cracks...
(What build # is your NA VX? And Europa subframe is a good one. thumbsup )
Edited by Exmantaa, 08 May 2014 - 10:48 AM.
#5 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 08 May 2014 - 10:56 AM
Might be some more useful pics in my build album.
http://s738.photobuc...ary/VAX Project
Edited by Crabash, 08 May 2014 - 10:59 AM.
#6 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 08 May 2014 - 11:44 AM
From the few N/A's I have spent time with it's as Steve states and the only real difference I could see. Wishbones on turbo (other than brace bar position) have extra bracing on the outer sides.
If your really familiar with the N/A then the pics Steve has of the refurb I did on his will highlight them
DG
#7 vocky
Posted 08 May 2014 - 11:49 AM
my 2003 NA is one of the last (build 4630) and has the earlier subframe  thumbsup
Edited by vocky, 08 May 2014 - 11:49 AM.
#8 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 08 May 2014 - 11:54 AM
Was this just strengthened to take the massive weight of the turdo engine 😃 ?
#9 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 08 May 2014 - 11:55 AM
I seem to remember, us checking something else out on the NA for guidance with the rebuild of mine, heads under car, look up, "hang on that's different". Not something I had ever heard referred to prior to that afternoon.
#10 Exmantaa
Posted 08 May 2014 - 04:40 PM
I see it now. The backplate from the turrets ais angled towards the crosbeam, while the older NA version goes straight up with only a small section angled 45° to the crossbeam. thumbsup
But heard that the later ones are some 2-3kg heavier and for sure that is not only from those 2 extra sections of backplate??
#11 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 08 May 2014 - 04:51 PM
Never thought to weight it at the time. But no way the extra bits would weight that much, so either it's not true or there are significant differences elsewhere, which I couldn't see. Possible they used a thicker steel sheet for that back section too I suppose.
