no play or marks on rotors
Comes with:
Inlet manifold
Inlet gasket
Tb gasket
68 mm LSJ throttle body
Inlet manifold bracket
Actuator
2 bar map sensor and bracket
All bolts to fit (most non genuine GM parts)
LSJ injectors so fit straight onto standard loom & also work with Dutch software & works with OBD tuner
(One O ring missing from injector)
Good for 250 bhp.
£850 collected from Poole or courier can be arranged at your cost but will only send with insured value.
