Vx220 Rear Lights Racing Lenses
176 replies to this topic
#1 GMS
GMS
  • 154 posts
Posted 20 May 2014 - 07:07 PM
Vx220 Rear Lights Racing Lenses for sale. They are made from the same material as OEM. The price is £80 per set with the edges roughly cut (requires smoothing out) and unpainted.
The result of finished process.
#2 gingerjon
gingerjon
  • 587 posts
Posted 20 May 2014 - 07:11 PM
I'll take a set Please. Will PM
#3 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 20 May 2014 - 08:11 PM
I'll have a set please.
#4 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 20 May 2014 - 09:27 PM
So is it just me that can't actually make out what your selling? Replacement lenses or some "racing" ones that stick over the top or what?
#5 speedster norway
speedster norway
  • 162 posts
Posted 20 May 2014 - 09:34 PM
Can I have 2 set please? PM on the way.
#6 techieboy
Posted 20 May 2014 - 09:45 PM
Replacement lenses that will need some refinishing if you want a proper OEM look, is how I'm reading it. If you're a racer and are more bothered about function over appearance, then they're probably good to go straight away.
#7 Zoobeef
Zoobeef
  • 11,103 posts
Posted 20 May 2014 - 09:48 PM
I see. Think I'm just going to replace the whole light units with fibreglass ones once I've decided on some cheap brake/tail/indicators to go in them. Could do with one replacement lense though as one of mine has a cracking in it. Hmm.
#8 jfalesi
jfalesi
  • 21 posts
Posted 21 May 2014 - 04:45 AM
Hello, same question as above: I have a cracked right lens at home that could do with a new glass...
#9 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 22 May 2014 - 04:23 AM
Same quesiton as above. If these are replacement lenses, then I'd like a pair please.
Edited by Zuber, 22 May 2014 - 04:23 AM.
#10 jfalesi
jfalesi
  • 21 posts
Posted 23 May 2014 - 12:42 PM
So is it possible to get a rear driver side lens alone?
#11 GMS
GMS
  • 154 posts
Posted 23 May 2014 - 08:47 PM
At the moment only sold as a set. Everybody who wants to order, please send a PM. Thanks!
#12 Kieran McC
Kieran McC
  • 3,416 posts
Posted 24 May 2014 - 11:06 AM
You have a pm
#13 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 May 2014 - 10:15 PM
How come they are not finished at the edges? They do look good.
#14 techieboy
Posted 24 May 2014 - 10:35 PM
Because they're being cut out of a bigger piece of material with the use of an angle grinder, looking at the picture. These aren't perfectly finished vacuum moulded mass(ish) production parts like Fezzasus is doing for the fronts.
#15 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 May 2014 - 10:40 PM
Only reason I ask is because if there from a mould shouldn't they come out at a perfect size but like you said it's not mass produce like fezz ones. Still good tho and at least theres a supply of front and rear lights so screw you vauxhall for your shocking prices.
#16 brainjb
brainjb
  • 61 posts
Posted 29 May 2014 - 08:22 AM
PM SENT
#17 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 29 May 2014 - 08:43 AM
Has anyone got a set of these yet?
I also want a set, but I don't wanna buy something that isn't as good a finish as OEM
#18 GMS
GMS
  • 154 posts
Posted 04 June 2014 - 08:42 PM
From close look there can be some small imperfections visible. There is also a slight groove on the outside, where the inside edge is, because they are moulded from sheet on one side mold.
#19 mitm
mitm
  • 689 posts
Posted 04 June 2014 - 08:51 PM
Anyone need a n/s lens so we could split a pair??
#20 Dan r
Dan r
  • 666 posts
Posted 05 June 2014 - 04:55 AM
I just need a n/s, any chance they could be posted to different places if we cover costs?
