Project Unknown
306 replies to this topic
#1 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 20 May 2014 - 07:07 PM
What is Project unknown?
Well basically it is called unknown as I’m not really sure what I will do. My thought is I will just do what comes to mind at the time (or what gets suggested). I do plan to replace the front clam and bonnet and repair the remaining body work and get a full re-spray. While the car is apart it will get a suspension refresh along with a nice clean. Unfortunately due to me being away all of June and end of October to March this will not be a quick process.
The plan a long way down the road will be to get to approximately 300bhp (but I will look into that at a later date).
I thought I’d start from the beginning and run through everything that I have done since getting the car.
So I started looking for my first VX middle of last year and just kept checking various websites and on here looking for a decent NA with the aim of converting to a SC’d. Then at the end of October I had to go away to Norway with work which resulted in me not being able to check for a car as much as I would’ve liked to.
I then spotted a nicely priced SC’d car which needed a bit of love, arranged to pick it up while I was back for Christmas and paid the deposit.
Once I had got the car back home I went about trying to make it more personal to myself.
Car when I got it with a few changes (wheels painted black and lots of bright green bits).
Not long after buying the car I had a leak in the charge cooler which I did a quick bodge repair just to get it to stop leaking all over the floor.
As soon as I got that repaired I backed the car into the garage, I turned the key to the off position and the car stayed running. After a frantic 10 minutes searching and throwing up a thread for help I got a few quick messages back and it turned out to be a new ignition switch that was required. So I had to stall the engine and disconnect the battery with the ignition still on (butt twitching time).
Ordered a new ignition switch at only £6 and set about changing it over. At this point while waiting for the switch to arrive I set about covering the dash in Alcantra (well a cheaper knock-off).
By then my two weeks back in the UK for Christmas was up and had to fly back out to Norway for the next 3 months.
While I was away I got on the search for some new wheels to replace the NA wheels and some suspension to replace the standard Billies. Fortunately Graeme Lambert sent me a message informing me that he was just about to start his project and that he had a set of Compos and Nitron NTRs. So after some chatting we worked out a price and arranged for me to pick them up when I got back from Norway.
I also then decided I would like some turbo ears and got on to Johnnyboy and ordered myself a set along with a new charge cooler (as that still needs to be replaced) and a VSE to replace the turbo back box that was fitted.
On arrival back from Norway in mid March I got in contact with Graeme and made the final arrangements to come meet him at MBR to pick up the parts I had bought from him. Got them home and wasted no time getting all the parts fitted.
Car with new wheels and suspension fitted along with a homemade plywood splitter.
Before I get any slating about the black lights there is method to my madness and this is that there was a hole in the drivers side headlight and the rears were cracked so I used a bit of araldite and glued the holes, etc. up sanded them back and tint sprayed them to hide the uglyness of the araldite.
After a good few blasts out with a SW meet included I decided it was time to get the car up on stands, get the front off and change the charge cooler that was sat waiting to be fitted.
So I set about starting. Once the car was on stands and I had removed the front clam I decided I would have a look at getting the ABS light off and investigate why the horn wasn’t working.
I started with the horn and found that the spade connectors weren’t connected. So thinking “this will be an easy fix” I connected them and tested… Still nothing… I then set about testing the relay and checked the fuse and found them to be fine. Using a guide on here I managed to trace the problem to be between the steering wheel and relay. After some more testing this and that I decided to take the steering wheel off and in doing so the slip ring part fell apart and I found the coil inside was broken in three places. I bridged the gap on the the plug after the slip ring and the horn sounded. So I ordered a new slip ring.
With that issue solved I decided to move onto the ABS… I was originally told that it had an ABS cut-off switch so I set about looking for that (it wasn’t where I had first thought). After about half an hour I followed the wires and found the switch located under the dash. Flicked the switch and still nothing I then went onto checking to see if all the sensors were getting power, so got the voltmeter out and checked and they were. I haven’t got around to checking the sensors but have decided I will change all the hubs when I rebuild the car so they’ll all be changed then (fingers crossed solving the ABS issue).
Last night having fully committed to the decision that I was going to rebuild the car I decided to get the rear clam off as well. Once again got myself on the internet after failing to figure it out myself did a quick Google search for a guide and loaded it up.
Few acton shots
Following the guide about an hour later (due to a misread from the wife about the filler cap) the rear clam was off.
And you’ll never guess where the clams are now…
Much to the Sam’s dismay they are in the Dining room. :lol:
#2 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 07:09 PM
Today I bought a nice Karcher steam cleaner and did a little test on the front left. Works quite good will need to give it a good scrub as well.
Please ignore the state of the wishbones I will be removing them getting them sand blasted and powder coated. Whilst I'm doing this I will be getting the Nitrons refurbished.
#3 CHILL Gone DUTCH
Posted 20 May 2014 - 07:16 PM
John turbos old car ??
#4 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 07:26 PM
Indeed it is. How'd you know that?
#5 CHILL Gone DUTCH
Posted 20 May 2014 - 07:42 PM
I've seen it many times Cracked light and that manifold
#6 CHILL Gone DUTCH
And the pipe from charge cooler
#7 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 07:46 PM
Haha Oright fair one. Well all that will be getting changed
#8 CHILL Gone DUTCH
Posted 20 May 2014 - 07:47 PM
Why are you not keeping manifold ??
#9 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 20 May 2014 - 07:48 PM
Thats where ive seen it before.
Looks like she is in good hands again
#10 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 07:49 PM
I will be for now but I imagine with wanting to get a ball park of 300 in the future it would have to chane at some point?
#11 CHILL Gone DUTCH
Posted 20 May 2014 - 07:51 PM
That manifold is one of the most expensive manifold money can buy!! And will easy get 300 ponies
#12 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 07:53 PM
I know it's an expensive one (and looks the dogs) wasn't sure if I'd be able to get enough out of it... But if your sure ill probably be able to convince myself to keep it :lol:
#13 CHILL Gone DUTCH
Posted 20 May 2014 - 07:55 PM
Dutch software 2.5 inch exhaust Forged engine and your there
#14 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 07:57 PM
Obviously your one of the guys il be looking to for advice when I get there then? :lol:
#15 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 20 May 2014 - 09:50 PM
I've just had all my wishbones and brakes spraid alian green. Not yet seen them so good to see what they could look like. Ps. I know I'm not one for spelling but your thread titles missing an 'N'. ;)
#16 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 09:52 PM
That should look good!! Will be interesting to see that. Oh yh cheers never noticed that :lol:
#17 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 20 May 2014 - 10:07 PM
anyone any idea on how to update the Title?
#18 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 20 May 2014 - 11:13 PM
I like the thread title as it is :lol: unique! Just get shot of the green interior stuff. Yuk
#19 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 20 May 2014 - 11:30 PM
Good work al. Car looks great on the compos mate. Looking fwd to seeing you crack on with the rest of it.
#20 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 21 May 2014 - 05:59 AM
:lol:
    Bing (1)
