Project Unknown
306 replies to this topic
#181 Nev
Posted 16 April 2015 - 01:26 PM
Hooorah, fingers crossed that this plastic roller skate is on the road for next weekend :)
Edited by Nev, 16 April 2015 - 01:27 PM.
#182 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 16 April 2015 - 01:28 PM
I am hopeful had a chat with the mot guy he seemed quite confident with what has been changed that there shouldn't be any major issues. I was worried about all the talk of rusted brake lines but mine aren't even slightly corroded. Hopefully the weather will be good next weekend
#183 tommobot
tommobot
  • 1,008 posts
Posted 16 April 2015 - 01:55 PM
Looks good! Shame you can't really make out the wheels :(
Have you got a link to the guide please?
#184 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 16 April 2015 - 02:05 PM
Looks good! Shame you can't really make out the wheels :(   Have you got a link to the guide please?
How's you mean about the wheels?... Which guide you after? The suspension one?
#185 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 16 April 2015 - 02:10 PM
Did you invert the front calipers while bleeding? Also the ABS module sometimes traps some air.
#186 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 16 April 2015 - 02:12 PM
I've got 4 pots on front so shouldn't need to do that? I know about the ABS trapping it and that I need to get it to kick in to get rid of the air but wouldn't have thought that it having air in would cause spongy pedal? If the fluid can't get to the air surely it has no effect until the ABS kicks in?... Or is that wishful thinking?... Lol
#187 Zoobeef
Zoobeef
  • 11,103 posts
Posted 16 April 2015 - 02:31 PM
Ahh no it shouldn't do unless you've moved the 2 pots to the rear.
Activating the abs on some loose gravel has shaken it loose for some!
#188 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 16 April 2015 - 03:28 PM
Nah still got the original brembo on the rear. I've re bled them again with an EZ bleed and have got a far better pedal. So will see how it goes...
Edited by Mopeytitan, 16 April 2015 - 03:29 PM.
#189 tommobot
tommobot
  • 1,008 posts
Posted 16 April 2015 - 03:46 PM
Ah sorry, thats my works PC screen being rubbish... Clearly visible on the phone  :dry:
Yeah, a link to the suspension set-up if it covers the Geometry aspects aswell?
#190 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 16 April 2015 - 09:07 PM
Ok guys having a massive issue at the minute. No matter what I do I can't get the brakes bled! What are the symptoms of a failed master cylinder?... Going to have to cancel the MOT tomorrow as it won't pass with a crap spongy pedal! I've bled 4litres of 5.1 through the bloody car and still a sh*t pedal!!! Argh!!! Any help will be much appreciated, I'm almost giving up on the car now! I feel like it doesn't want to go on the road!!
#191 tommobot
tommobot
  • 1,008 posts
Posted 16 April 2015 - 09:28 PM
If your using the exibleed still check the seal on the top of the bottle, if it sits wrong it let's air in as I have found at before...
#192 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 16 April 2015 - 09:33 PM
It doesn't seem to be leaking when it was connected I couldn't hear any noises and there was no visible signs of leaking from the connections. I'm going to have to order some more fluid and just keep trying. If it is the master cylinder I'll have to wait till I get paid :( Bloody hate this stupid plastic POS!!!!
#193 FLD
Posted 17 April 2015 - 08:07 AM
If the MC is gone you normally get fluid running down the servo.
#194 oakmere
oakmere
  • 2,143 posts
Posted 17 April 2015 - 10:23 AM
It will be air trapped in the abs unit. Take it the Vauxhall for a Tech 2 bleed.
#195 oakmere
oakmere
  • 2,143 posts
Posted 17 April 2015 - 10:27 AM
Also just checking you have turned the front calipers upside down when bleeding? As air can never get from the back side of the calipers due to link pipe at the bottom.
#196 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 17 April 2015 - 10:28 AM
I've got 4 pots on the front. Would air in the ABS cause a spongy pedal?
#197 Zoobeef
Zoobeef
  • 11,103 posts
Posted 17 April 2015 - 12:00 PM
Im not sure on the inner workings of the abs unit but even not activated there may be chance to it to catch on the tight passageways.
You can activate it on a loose surface then re - bleed.  Saves using a tech 2.
#198 siztenboots
Posted 17 April 2015 - 12:03 PM
iirc the abs block is sealed, so probably air trapped would be from it being a high point in the system
#199 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 17 April 2015 - 05:50 PM
So after bleeding the brakes and the clutch all morning (about 5 times) I managed to get a half decent pedal feel. got convinced to take the car for its MOT...
So it started with a bit of a bad start... We were abit cautious driving the car in as there was a bit of a bump to get in originally but it got in. Roger took the VIN number to confirm the car details and straight away he flagged up
"It says the car is silver?... It definetely doesnt look silver to me"
To which i replied "It used to be Silver haha"
I'll start with the good bits. It PASSED!!!
But fortunnately Roger was a friend of Alex (Gorbachov on here) and the car got through with a few how should we call it "advisories".
I'll list them :lol:
1.     Both headlights need adjusting. Pax is about half inch low and drivers is high.
2.     Brakes... Well what can i say!!! I knew they'd be sh*t but we are putting it down to the fact they are new disks and pads and there is still some air stuck in the system.
3.     Emissions. everything bar the Lamba portion passed with flying colours. It was soo close to the limit! Any ideas what I could do to sort that for next year??
4.     One of the gators on the steering rack has a slight split (annoying as i missed it when i had the rack out!!)
So not all bad considering it was in a million peaces not so long ago. :lol:
I had smoke bellowing from the radiator (putting this down to some break fluid that i spilt on it :ffs: ) and the heat sheild part that is attached to the boot wasn't place correctly and was touching the manifold so loads of smoke from both ends!! :lol: was stressfull to say the least! But once the break fluid had burnt off it stopped smoking and once i had moved the heat sheild bit it stopped aswell. So it didnt catch fire!!
Oh and wow does my TMS manifold glow when it held at 3k revs!! Was really cool if you looked past it trying to set fire to the car. :lol:
So all in all a failry stressful day but it passed albeit i have a few jobs to sort out but atleast i can now legally get out and bed the brakes in and try to sort out the air thats trapped. thumbsup
Car next to Alex's getting ready to go to the MOT station.
Few outside the MOT station
In MOT station
Al
#200 VegyBS
VegyBS
  • 183 posts
Posted 20 April 2015 - 10:06 PM
This is exactly what I envisioned my VX will eventually look like when I have one.
    Bing (1)
