Rear Spoiler
Posted 26 May 2014 - 07:20 PM
Posted 26 May 2014 - 08:00 PM
Probably does sweet fa. Its too low down and out of the airflow really to do anything. Mainly for show.
Have you got an NA ? The turbo clam has the holes predrilled to mount the spoiler but of course the NA doesn't so you would have to drill your own.
Post in wanted or buy from vauxhall, autovaux, ElizP987.
Posted 26 May 2014 - 08:41 PM
Posted 26 May 2014 - 08:45 PM
Posted 26 May 2014 - 08:55 PM
Posted 26 May 2014 - 08:57 PM
'Wings' work. To what degree depends on how high you've mounted it, how big it is etc.
The most common option is to fit the exige gt4 'pramhandle' wing. Available from EliseParts.
How well this works in practice is not really known. It definitely does something on the exige because its been wind tunnel tested but the exige and the VX are not the same shape so the airflow is different.
You will have to trim the mounts down to still be able to use the boot and drill holes in the clam for fixings.
http://www.vx220.org...e-how-to-guide/
Posted 26 May 2014 - 09:02 PM
Posted 26 May 2014 - 09:03 PM
Posted 27 May 2014 - 05:12 AM
Posted 27 May 2014 - 06:02 AM
If it really does anything even if 1% more then im happy, who knows, but I think it looks good fitted.
Don't forget the rest of the car setup, i.e front splitter, shocks, tyres, brakes etc
Posted 27 May 2014 - 06:18 AM
Looks good! Your pic has answered my question re. Boot spoiler; mine will look better oriented, definitely.
Posted 27 May 2014 - 08:24 AM
There's some pics of mine in this thread. However, your prerequisite of 'bolt-on' might be a bit tough to meet. Wings like these require some bracing to the clam (although I believe tubby clams are stiffened) to tranfer any effect to the subframe and subsequently to the wheels. From what I have seen this has all been home made and is often cut through the clam.
Posted 27 May 2014 - 08:42 AM
Posted 27 May 2014 - 09:01 AM
Of course you could make a custom bracket inside the boot that sits between the subframe and the spoiler.
That way you only drill a few holes in the clam for the spoiler mount, versus cutting complete slots for the brackets like in pics above.
edit: different type of spoiler mount for those though. (compared to above pixies)
Edited by smiley, 27 May 2014 - 09:12 AM.
Posted 27 May 2014 - 09:10 AM
I forgot that turbo clams are reinforced. That explains why my spoiler stays on at high speed. In that case Krusty completely ignore what I told you at Bedford as you have an N/A clam.
Posted 27 May 2014 - 09:24 AM
Really?
Are you sure?
I thought the only difference between tubby and NA clams, is the boot aperture.
Posted 27 May 2014 - 09:35 AM
Pretty sure there should be a brace between the inside of the clam and the boot floor to transfer the massive downforce pressures
My TMS one had a suitably gash effort
Posted 27 May 2014 - 09:54 AM
Your completely right..Pretty sure there should be a brace between the inside of the clam and the boot floor to transfer the massive downforce pressures
My gash effort, although it does the job and i can still use most of the boot.
