Rear Spoiler
50 replies to this topic
#21 FLD
Posted 27 May 2014 - 10:32 AM
I forgot that turbo clams are reinforced. That explains why my spoiler stays on at high speed. In that case Krusty completely ignore what I told you at Bedford as you have an N/A clam.
Really?
Are you sure?
I thought the only difference between tubby and NA clams, is the boot aperture.
The upper part of tubby clams has a thickener part added making it a fair bit stronger.  Not sure I'd rely on it for a BGW but it is a lot stiffer.
#22 FLD
Posted 27 May 2014 - 10:55 AM
Here's a pic of my internal brace.  Its been a 'make do' fix for 2 years :D.  Must make a proper one.
#23 chris_uk
Posted 27 May 2014 - 11:02 AM
Yea mine was a "make do" one aswell and has worked well and never been a problem lol
#24 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 27 May 2014 - 11:43 AM
Mine is just very big washers.
I can pull my car in to the garage by the supports fine, clam is fine for the last year.
#25 scw02102
scw02102
  • 1,581 posts
Posted 27 May 2014 - 11:45 AM
Do you need internal brassing for the GT4 spoiler?
#26 peteslag
peteslag
  • 919 posts
Posted 27 May 2014 - 11:51 AM
6 track days completed with speeds of 140 MPH reached quite a few times. I've checked very carefully around the area where the spoiler is mounted and there are no signs of damage. Mind you, I think mine will only give about 30-40 kg's of downforce depending on speed. The spoiler mounts are very wide and I've used enourmous repair washers on the other side to help spread the load. I'm fairly sure I could sit on it and not cause any damage and I weigh 85 kilograms (not that I would, my neighbours might think I'm a bit weird). I suppose it depends on what sort of spoiler you want to fit and how much downforce is required. Anyway, I doubt this matters to the original author of the thread as he has an N/A.
#27 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
You don't need bracing like the examples above but some people as I did have fitted a precautionary spreader plate directly under the legs onto the roof of the boot. Although I'm sure a lot don't bother and have been absolutely fine just bolted through the clam.
Edited by -Dab-of-Oppo-, 27 May 2014 - 11:54 AM.
#28 siztenboots
  • 26,613 posts
Posted 27 May 2014 - 11:59 AM
I think the internal fixing of the captive nut on the wing upright is the weakest point
#29 chris_uk
Posted 27 May 2014 - 12:12 PM
Its not a case of reducing damage to the clam, its about transfering the downforce onto the wheels. If you dont have a brace all that will happen is you will push the clam edge down.
#30 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 27 May 2014 - 12:22 PM
when I push down on my GT4 spoiler it moves the whole clam lower, I have massive spreader plates that take up all the flat area under the wing mounts..
If the GT4 spoiler actuallyy does anything? Then Im sure most of it gets to the wheels.. but being honest I just love the way it looks :wub:
#31 scw02102
scw02102
  • 1,581 posts
Posted 27 May 2014 - 12:28 PM
Stuwy, where the best place to get a spreader plate? B&Q?
#32 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 27 May 2014 - 12:32 PM
any piece of A4 sheet aluminium cut it down to fit per side, should cost less then £4 each side.. fortunately mine come with the spoiler when I bought it.. so I just bolted it all together
#33 FLD
Posted 27 May 2014 - 12:33 PM
A few years back when BGW's were first attached to clams there were a few that had stress cracks in the clam top after a few months.  This was with no spreader or bracing.  I think its wise to put something in.
#34 techieboy
Posted 27 May 2014 - 12:34 PM
This thread just proves all VX's look sh!t with wings on.
#35 scw02102
scw02102
  • 1,581 posts
Posted 27 May 2014 - 12:38 PM
Got mine from Serious Lotus so not sure if it came with one as its all at the spray shop
I will pop down B&Q and buy an aluminium sheet, then I take it just cut drill some holes to bolt it through
#36 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 27 May 2014 - 12:40 PM
No they don't!!
#37 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 27 May 2014 - 12:54 PM
yes, make sure its not too thin as it needs to add redigitady (fcuk knows how you spell that)
once you have one cut to the right shape, you can then use it as a template for the other side, and then again as a template so you drill the holes in the right place...
I let my old man use a hand drill on my clam, I could not do it myself :lol:
#38 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 27 May 2014 - 01:05 PM
Here is my solution.
I have added a second rivnut to the subframe so the channel is firmly held in 2 places. I have also stuck the channel to the boot floor so I can remove the clam without having to take the whole wing assembly out. Where the upright comes through the clam is sealed to allow the boot to be used.
https://www.flickr.c.../124859788@N06/
@Techie; I'm immune to your BGW jibes :wub:  :drink:
Why can't I get the pic to display? Thought I'd followed the instructions. Can admin help?
Edited by techieboy, 27 May 2014 - 01:34 PM.
#39 techieboy
Posted 27 May 2014 - 01:09 PM
Your car looked so much better at Silverstone, wingless. Probably also upped your top speed by 10mph as well. :D
#40 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 27 May 2014 - 01:15 PM
Yes yes yes but can you display the pic so others can easily agree with you!
