Can you translate that steve Thanksactually the memory was not so bad http://www.ohizumi-m...chnote1.html#a7 7. Thermal time constant A thermal time constant γ is defined to be a constant indicating the degree of thermal responsiveness of a thermistor. No thermistor operation can be free of a time lag because the thermistors every operation is a thermal phenomenon. Thermal time constant γ is the period of time necessary for a thermistor temperature to change by 63.2% when wattage is applied to the thermistor and an abrupt change is made to it from a heat equilibrium state to a zero load state.
The part that's missing in that definition is the temperature interval. The T63 response time is the time it takes for the sensor to reach 63.2% of the total temperature interval. I assume for this TMAP that's 170 degrees (-40 to +130 C). 63% Of that is about 107C. Going from -40 to +67C (or from 0 to 107C) will take 10 seconds. In the datasheet there is a note indicator at the 10 sec value. Too bad the note isn't there, as they might have used a different interval.
