Supercharged Intake Temps
443 replies to this topic
#261 CHILL Gone DUTCH
Posted 26 June 2014 - 11:39 AM
I've looked over a number of files and there is no evidence that the temps altered with my ignition Do you think we could all have constructive criticism rather than criticism
#262 slindborg
Posted 26 June 2014 - 12:38 PM
It was an honest question to verify understanding before going forwards ;) Maybe I should edit my list as its annoying to click a few times in a thread :lol:
#263 CHILL Gone DUTCH
Posted 26 June 2014 - 01:24 PM
At least were on same team lol Do you think that the ignition could be possible
#264 Hopegreen
Hopegreen
  • 94 posts
Posted 26 June 2014 - 02:51 PM
I think ignition is quite important when you talk about cylinder temps but having high values of AIT seems to me that could be some problems with laminovas, rotors or PCV. Don't know if enough "bad" ignition could heat AIT.
#265 CHILL Gone DUTCH
Posted 26 June 2014 - 03:01 PM
PCV is a good point On a other thread I've been discussing that in quite some depth I've gone back to oem and do far I have no oily substance in the inlet system Can't comment on the laminovas until I take them out in winter but I'm hoping they won't be fowling up either But getting back to the ZzP stage 2 cams I had to add over 3 degrees of advance from what peter thought would be a safe starting point to get them to make any kind of power We could in bargi case have more than one variant in his high temps
#266 slindborg
Posted 26 June 2014 - 03:16 PM
Are the cams a) designed for forced induction applications b.) designed to run on OEM timing setup but give the right overlap or c.) run on the mental priced vernier pulleys to give the correct overlap...
Head temp, radiating into the inake would only pose an issue in terms of sensor heat soak and the actual air temp may just be fine but the calibration dumps fuel in etc
#267 vocky
Posted 26 June 2014 - 03:28 PM
Bargi has LSJ Blower cams, which were correctly vernier'd with some Saab cam sprockets  thumbsup
Crap standard z22se exhaust manifold will be backing up the pressure and causing the extra heat  :P
Edited by vocky, 26 June 2014 - 03:29 PM.
#268 slindborg
Posted 26 June 2014 - 03:37 PM
I'd go as far as to say the backpressure would be hurting how the engine is breathing and thats the reduction in power.
Where in the manifold is this TMAP mounted?
#269 techieboy
Posted 26 June 2014 - 03:40 PM
On the right hand side of this pic
Effectively the inlet to cylinder 1
#270 slindborg
Posted 26 June 2014 - 03:57 PM
yeah, that'll heat soak its tits off :lol:
We had the A/C sensors in the Pagani going mental once it was hot... outside air temp wet from ambient to 50deg, the chamber temps were high yet the air coming out was still cool.
Edited by slindborg, 26 June 2014 - 04:01 PM.
#271 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 26 June 2014 - 07:01 PM
so how can we get an accurate temperature from inside the manifold then? the position as it is is post laminova so should.. be the temp entering the cylinders ps Matt how many manifolds do you have??:-)
Edited by NickB777, 26 June 2014 - 07:02 PM.
#272 CHILL Gone DUTCH
Posted 26 June 2014 - 07:24 PM
Phenolic spacer and a hose cold air feed direct on to sensor & on to the manifold near fuel rail?
Edited by CHILL Gone DUTCH, 26 June 2014 - 07:27 PM.
#273 slindborg
Posted 26 June 2014 - 07:30 PM
Before you go nuts, you need someone who is having the temp spikes to stick a thermocouple in there to get a non radiated temperature
#274 The Batman
Posted 26 June 2014 - 08:14 PM
I wish people Put this much effort into redesigning a new intake manifold
Edited by The Batman, 26 June 2014 - 08:15 PM.
#275 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
I'm running harrop on the Dutch software and I rarely see over 50 degrees on the inlet temps.
#276 CHILL Gone DUTCH
Posted 26 June 2014 - 08:19 PM
Phenolic spacer ??
#277 chris_uk
Posted 26 June 2014 - 08:26 PM
yes, but heat soak still happens, it would just take longer with the spacer on..
whats wrong with tapping the hole and putting a fitting in then mounting the map sensor away from the manifold.?
#278 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Here's a power run from a really hot muggy day where it was 21 degrees outside and I had been out for a couple hour drive before doing this power run. My car was also in the layby for 10 mintues ticking over while I was setting up the laptop and getting the software to work.
My power is down slightly because my weight was set a 1065 kg.
#279 chris_uk
Posted 26 June 2014 - 08:27 PM
ignore them temps...
you want to log 15 mins of driving and see what really happens.
#280 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 26 June 2014 - 08:35 PM
Hot day logging the other day
By looking at the box at the top my average is 48 degrees.
Edited by haggi961, 26 June 2014 - 08:37 PM.
