Supercharged Intake Temps
443 replies to this topic
#281 CHILL Gone DUTCH
Posted 26 June 2014 - 08:36 PM
yes, but heat soak still happens, it would just take longer with the spacer on..    whats wrong with tapping the hole and putting a fitting in then mounting the map sensor away from the manifold.?
The problem with that chris the reading would be wrong, I would imagine it was put there to give the reading going into the head If your going to falsify the readings you may as we'll take it out completely
#282 Exmantaa
Posted 26 June 2014 - 09:01 PM
Hot day logging the other day
By looking at the box at the top my average is 48 degrees.
Toddling around the block without really using the Harrop will not raise the temps much above that. :happy:
You should repeat that log with some laps on a track and you will se the IAT crawling up to 80-90*C...
But I agree with Joe; we just have a serious cooling issue and better put our thinking in some creative thinking. :D
#283 The Batman
Posted 26 June 2014 - 09:02 PM
I've been waiting 26 years for someone to agree with me :lol:
#284 Exmantaa
Posted 26 June 2014 - 09:04 PM
Measured your cams already?? :P
#285 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 26 June 2014 - 09:06 PM
That log was not taking it easy, I was fast road driving in most of it other then slowing down for traffic or junctions. I had my scan gauge connected when on the track day at Croft and my inlet temps stayed around 60 degrees and below, not sure how accurate the scangauge is tho.
#286 CHILL Gone DUTCH
How has lee got on with his idea ?? Could we use a air con system using lees rad
#287 The Batman
Posted 26 June 2014 - 09:10 PM
If you are gonna use air con uae it for the laminovas and you want need to mess around with a second rad
#288 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 26 June 2014 - 09:11 PM
I wouldn't say no to Lees idea if it works. Would be nice to try it on the Dutch software with before and after graphs.
#289 CHILL Gone DUTCH
Posted 26 June 2014 - 09:13 PM
Scuffers has already mentioned that the laminovas could be taking out a 100 degrees from the air and the water isn't getting Luke warm
#290 The Batman
Posted 26 June 2014 - 09:15 PM
They are very effective but nowhere near as effective as a air con system. Laminovas is also a restriction. As the air can't pass through them quick enough the pressure before them is building up causing more heat
Edited by The Batman, 26 June 2014 - 09:16 PM.
#291 Hopegreen
Hopegreen
  • 94 posts
Posted 26 June 2014 - 09:17 PM
I remember that stage 1 without laminovas reach up to 100 degrees more or less. Not 170.
#292 CHILL Gone DUTCH
Posted 26 June 2014 - 09:19 PM
Would you suggest chilling the water ?? With air con joe Tell me your thoughts !
#293 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 26 June 2014 - 09:21 PM
  Lastly, saw a comment about the crank vent earlier, in a SC car the very last thing you want is to recirc crank venting into the engine, oil vapour has a terrible octane rating and will effectively de-octane your fuel charge significantly, seem a lot of engines pushed into det because of this.   catch tank and filter away from the intake is the go..
Wouldn't blocking it off also cause problems the vapours to destroy oil seals and push pistons? I'm not sure which way is best but it's a 6 and two 3s problem.
Edited by haggi961, 26 June 2014 - 09:22 PM.
#294 CHILL Gone DUTCH
I was thinking of a air system rather than water using something similar to lees sandwich plate
#295 The Batman
Posted 26 June 2014 - 09:22 PM
My thoughts are either making the laminovas sealed for a air con system or replacing the laminovas with a rad and air coning that. Failing that removing the laminovas and using a rad like less for air con. Problem is with this is it's not for everyone due to not fitting on standard car (or am I wrong and it does fit?)
#296 slindborg
Posted 26 June 2014 - 09:24 PM
Air con won't cool fast enough. Think how slow it is in the cabin, then pump sh*t loads of very very hot air through it, it's not gonna work. By all means try it, as I clearly haven't a clue about air con (cv item, calibrated hvac system in several vehicles)
#297 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2014 - 09:26 PM
Hot day logging the other dayPosted Image
Luke, there's a key that has "Prnt Scrn" written on it, it's your friend :D
#298 The Batman
Posted 26 June 2014 - 09:27 PM
In that case then Maybe extending the manifold to add 2 more laminovas But then have to avoid starter motor
#299 CHILL Gone DUTCH
Posted 26 June 2014 - 09:29 PM
We are brain storming, but feel free to participate
#300 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Yeah but that then means I have to log into my girlfriends laptop and open the internet tab where talking a picture on the ipad is quicker lol
