Watering the intercooler
Posted 26 October 2014 - 12:37 PM
Posted 26 October 2014 - 12:46 PM
Lsj oneWhich pump do you install joe
Posted 26 October 2014 - 02:30 PM
You should really note ambient temps as well then - a cool day is obviously going to give lower IATs than a warm one.. I wonder how much use these reading will actually be without a complete picture. And even then there's so many variables..You're almost as preliminairy as me nowFrom just us to you can see advantage of more flow
Let's wait for a few more.
Posted 26 October 2014 - 02:53 PM
That's not how it work's here.
It's almost winter, so we draw preliminairy conclusions, build a list and start buying stuff
Posted 26 October 2014 - 03:46 PM
Yes good point. Worth just posting the power run results as they include the relevant variables.You should really note ambient temps as well then - a cool day is obviously going to give lower IATs than a warm one.. I wonder how much use these reading will actually be without a complete picture. And even then there's so many variables..You're almost as preliminairy as me nowFrom just us to you can see advantage of more flow
Posted 26 October 2014 - 04:56 PM
Edited by CHILL Gone DUTCH, 26 October 2014 - 05:03 PM.
Posted 26 October 2014 - 05:19 PM
Posted 29 October 2014 - 09:33 AM
Edited by CHILL Gone DUTCH, 29 October 2014 - 09:35 AM.
Posted 29 October 2014 - 09:35 AM
Posted 29 October 2014 - 09:44 AM
Which pump smiley
Given the very low weight of the small PAD pumps, would it be beneficial to flow to install a second pump at the front of the car..? Perhaps on the return line to the laminova's..
The relatively long and convoluted flow path of the cooling system will obviously result in some significant pumping losses..
Just a thought.
Posted 29 October 2014 - 09:58 AM
bear in mind that for the Bosch 0261230042 Tmap sensor the temperature sensor has a step response time (63% from t1 to t2) about 10 seconds, the pressure sensor about 1ms
Posted 29 October 2014 - 11:01 AM
MCMWatering the intercooler
Posted 29 October 2014 - 11:55 AM
They've just released an update to that video. The results
Not to bad actually
Posted 29 October 2014 - 12:03 PM
Presumably you need a tmap sensor to contribute to this? Or are you happy with standard map sensor equipped cars?Rather than clogging up sworks project thread I'm after getting information of SC IAT Can you post Type of rad Type of CCpump ( flow rate ) Single pass or dual pass And some logs or temps expiereicing
Posted 29 October 2014 - 12:09 PM
Posted 31 October 2014 - 10:17 PM
Edited by CHILL Gone DUTCH, 31 October 2014 - 10:21 PM.
Posted 09 November 2014 - 10:01 PM
Bit of an update.
Turns out the relay for the charge cooler pump was failing which I believe explains the high temps. Full story here and here
Tonight after bypassing the relay I was seeing much lower temps on the motorway.
Cruising was solid 37 degrees and rose and dropped with acceleration and deceleration much quicker than it was before.
While this is still comparatively high, it's better than the 60s-70s I was getting previously.
But one thing bothers me...
After the first session I could barely take the cap off CC tank (Pro Alloy type in engine bay) it was so hot and saw some steam/vapour when I took the cap off.The sides of the CC tank were to far to hot to touch.
After I got the pump running the CC tank was barely hot at all, even when checked straight after coming off track.
There's a lot of heat going somewhere!
My conclusion from this is the charge coolant is adsorbing a lot of heat from the engine bay via the ally CC tank.
Looking at the IATs, at least 20 degrees worth.(if that's actually a valid way to describe it)
So Smiley and Chris were on the right track about the bigger pumps and lower IATs, but not from removing more heat from the intake air but from what the CC tank is absorbing. (and maybe the pipes and CC carrying bits)
I guess CS were onto something with the CC tank in the boot.
I'll try get some power runs this week to compare with my previous ones from a few weeks back.
May even need to do a new set of fuel learns given such a big difference.
Posted 09 November 2014 - 10:05 PM
These electric pumps do have a limited life span, I wonder how many charge cooler pumps are actually working.
There are in line flow meters that can tell you if it's working, or I guess a system to measure resistance across the pump. I'll have a play and see where I get to
