yup...
other point worth making is that if the engines happy running at X boost and Y IAT's, then reducing the AIT's further whilst a laudable goal, does not actually gain you anything (unless you're going to speed up the SC or add more advance)
by reducing the AIT's, you should actually see a reduction in boost, as the air mass you are dealing with will not change (that's a function of the SC drive ratio and air intake temps to it minus a bit of air leakage around the rotors).
not suggesting 90C is good, but are you actually having to pull timing off to keep out of det at this point and thus losing some potential HP?
and before you rush off and install water injection, just consider for a moment what effect this will have on your laminova cores... (assuming you're planning on using it at the SC inlet?)
Lastly, saw a comment about the crank vent earlier, in a SC car the very last thing you want is to recirc crank venting into the engine, oil vapour has a terrible octane rating and will effectively de-octane your fuel charge significantly, seem a lot of engines pushed into det because of this.
catch tank and filter away from the intake is the go..
