All this talk of failures is almost making me scared to drive the car!
I know how you feel but I for one am going to get straight back on that horse.
Posted 03 July 2014 - 01:08 PM
Posted 03 July 2014 - 01:15 PM
Someone hasn't paid the bill
Posted 03 July 2014 - 01:17 PM
Posted 12 July 2014 - 04:27 PM
Posted 12 July 2014 - 05:50 PM
Mark what makes you say the outer joints aren't a problem. ? The one I saw snap in Wales luckily at slow speed on the straight was an outer (all standard) The one a few week back was luckily also not at speed. While looking at it under the car I remember all the comments on my thread with folk saying " oh they never snap while straight only under heavy cornering " made me smile. They can most definitely snap either inner or outer at any time even as you ease it into the garageThis is from 2007, http://www.lotustalk...toe-link-42434/ also http://www.lotustalk...e-links-136217/ lotus addressed the issue by doing 2 things (primarily for the inner joints) 1. offering a stabilizer bar (ultimately a factory add-on to the Exige in later years) 2. posting a bulletin on checking the torque of the joint bolts (apparently coming to the conclusion that the inner joints became loose thus causing them to shear over time from excess stress). if I recall, many dealers did offer to retorque the bolts as a recall service. either way the current solutions for the rear toe link arms are primarily to address the inner joint from shearing (whether its BOE/Sector/ect they are all legit options) but the stock outter joints aren't really a 'problem' spot (like the inners) & even after the unfortunate incident with 'Ying' I still wouldn't consider the outter joints an overall issue... but with that said if you address the inner joints with one of the aftermarket options, its certainly a good idea to check for wear on the outters as a piece of mind
Posted 12 July 2014 - 05:53 PM
So where can we get just new bolts?
Martin S
Posted 12 July 2014 - 07:53 PM
Agree from personal experience, mine failed driving 40mph on a straight bit of road. Phoenix are now doing a complete suspension refresh with Seriously Lotus kit. They recommend it and I'm not in a position to argue.Mark what makes you say the outer joints aren't a problem. ? The one I saw snap in Wales luckily at slow speed on the straight was an outer (all standard) The one a few week back was luckily also not at speed. While looking at it under the car I remember all the comments on my thread with folk saying " oh they never snap while straight only under heavy cornering " made me smile. They can most definitely snap either inner or outer at any time even as you ease it into the garageThis is from 2007, http://www.lotustalk.com/forums/f101/check-your-toe-link-42434/ also http://www.lotustalk...e-links-136217/ lotus addressed the issue by doing 2 things (primarily for the inner joints) 1. offering a stabilizer bar (ultimately a factory add-on to the Exige in later years) 2. posting a bulletin on checking the torque of the joint bolts (apparently coming to the conclusion that the inner joints became loose thus causing them to shear over time from excess stress). if I recall, many dealers did offer to retorque the bolts as a recall service. either way the current solutions for the rear toe link arms are primarily to address the inner joint from shearing (whether its BOE/Sector/ect they are all legit options) but the stock outter joints aren't really a 'problem' spot (like the inners) & even after the unfortunate incident with 'Ying' I still wouldn't consider the outter joints an overall issue... but with that said if you address the inner joints with one of the aftermarket options, its certainly a good idea to check for wear on the outters as a piece of mind
Posted 13 July 2014 - 08:35 AM
Posted 13 July 2014 - 09:19 AM
It's a lot of years since I studied this sort of application but I do remember an experiment we ran while I was studying NDT. The weakest point on a hex bolt is the transition between thread and the shoulder so we performed a test on a Denison tensile test machine to prove this. Setting up a four plate lap joint sample held together with eight bolts, we set up four bolts with the thread transition level with the plate inner edge and four bolts threaded right through the plates and then pulled them apart with the bolts in shear. As expected the bolts sheared at the transition. I'm not familiar with the makeup of the joints were the threads start and finish but as Bradley says above; having a close fit shaft right through the joints would be an improvement. I can't remember the valves measured (it was 30 years ago) when we went back and pulled the other end apart the values were dramatically higher.
It went with a hell of a bang aswell
Posted 13 July 2014 - 09:50 AM
Posted 13 July 2014 - 10:12 AM
Edited by Jason, 13 July 2014 - 10:30 AM.
Posted 13 July 2014 - 10:28 AM
This is interesting read http://www.lotustalk...177/index2.html
Less interesting than when it was linked to in post 3 of this thread.
Posted 13 July 2014 - 10:34 AM
Posted 13 July 2014 - 01:00 PM
Martin S
Yvo has put the uprated bolts onto the site : http://www.elise-shop.com/toe-link-replacement-109-bolt-kit-vx220-p-502715.html
Posted 13 July 2014 - 02:44 PM
Link is not working
Posted 13 July 2014 - 06:56 PM
Here you go:
http://www.elise-sho...0-p-502715.html
This good news but extremely frustrating. I've literally just had my toe link kit fitted with standard bolts. Stupid bloody plastic Lotus wannabe cars!
Posted 13 July 2014 - 10:00 PM
If you don't track it make sure you replace them every 50K miles just for peace of mindHere you go: http://www.elise-sho...0-p-502715.html This good news but extremely frustrating. I've literally just had my toe link kit fitted with standard bolts. Stupid bloody plastic Lotus wannabe cars!
Posted 15 July 2014 - 02:05 PM
My bolts from an uprated phoenix kit have been on the car for 25 plus track days and around 20000 miles on 888's, all seem ok, but am replacing them out of paranoia now.
Martin S
