Bumblebee's New Seats
Posted 03 July 2014 - 08:33 PM
Posted 03 July 2014 - 08:46 PM
Posted 03 July 2014 - 08:55 PM
Posted 03 July 2014 - 09:04 PM
Why do you need harnesses ?
Posted 03 July 2014 - 09:08 PM
Where the buggery did you find them? I would have loved them in me old LY
Posted 03 July 2014 - 09:09 PM
Because they look prettyWhy do you need harnesses ?
Posted 03 July 2014 - 09:10 PM
Take your drivers side inner sill off and sort the side pocket out
Nice
Posted 03 July 2014 - 09:14 PM
No other reason needed IMO
Posted 03 July 2014 - 09:20 PM
Your harnesses aren't fitted properly. The ASM shoulder strap is meant to be fitted on the inboard shoulder not the outboard. There also shouldn't be any loops on the harness bar, the buckle should be hard up against the harness bar with no slack.
Posted 03 July 2014 - 09:24 PM
How do you know which strap is which? Sorry for the hijack! Lovely seatsYour harnesses aren't fitted properly. The ASM shoulder strap is meant to be fitted on the inboard shoulder not the outboard. There also shouldn't be any loops on the harness bar, the buckle should be hard up against the harness bar with no slack.
Posted 03 July 2014 - 09:26 PM
The big yellow tab at shoulder level is the ASM bit (basically a bit of harness stitched back on itself that's meant to break on an impact).
Posted 03 July 2014 - 09:31 PM
Posted 03 July 2014 - 09:32 PM
fcuk me! TMS have actually fitted something right on my car. After 7 years of ownership I have finally found something done right! Maybe I've been too harshThe big yellow tab at shoulder level is the ASM bit (basically a bit of harness stitched back on itself that's meant to break on an impact).
Harnesses are horrendous for anything other than track work. You might even argue that they're dangerous because you can't lean forward to get a good view of the traffic.
When on the road, I used to push mine back through the holes and secure them behind the seat. I left the normal seat belts in the car and used those.
Seats look fantastic though
Edited by Gedi, 03 July 2014 - 09:41 PM.
Posted 03 July 2014 - 09:34 PM
Probably only because it had to pass scrutineering and the scrutineer pointed it out.
Posted 03 July 2014 - 09:40 PM
This x1,000,000Harnesses are horrendous for anything other than track work. You might even argue that they're dangerous because you can't lean forward to get a good view of the traffic.
