Crack Appeared On Mirror Surround - Should I Be Worried ?
cracks bodywork
10 replies to this topic
#1 kmidderigh
kmidderigh
  • 349 posts
Posted 19 July 2014 - 11:50 AM
This crack appeared the other day on my drivers side mirror pillar :   https://www.dropbox....6c/DSC01771.JPG   wondering how it got there ? someone thumped the mirror ? stress crack due to driving repeatedly at 'some miles per hour' :-)   doesnt seem loose if i waggle it a bit - worth reparing ?
Edited by CocoPops, 20 July 2014 - 09:23 AM.
#2 Spitfire Engineering
  • 755 posts
Posted 20 July 2014 - 08:17 AM
Looks like the miror may have been smacked?
does it enlarge if you pull the mirror back?
#3 FLD
Posted 20 July 2014 - 08:40 AM
:yeahthat:
If it does, open it up then squirt in some structural adhesive.
#4 CocoPops
CocoPops
  • 17,181 posts
Posted 20 July 2014 - 09:13 AM
I'm sure that is normal... It's where the door skin meets the door panel. There is normally a body coloured sticker over the top.
#5 CocoPops
CocoPops
  • 17,181 posts
Posted 20 July 2014 - 09:22 AM
Like so...
(Ignore the red box but you can see the sticker shape)
#6 Spitfire Engineering
  • 755 posts
Posted 20 July 2014 - 02:52 PM
good info   :)
#7 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 20 July 2014 - 05:36 PM
Hard to tell because of the reflections but it looks much more like a surface crack to me. It runs down nearer the middle and has a much more jagged line than those straight cut protective vinyl pieces.
#8 CocoPops
CocoPops
  • 17,181 posts
Posted 20 July 2014 - 05:38 PM
In the op pic, the cut vinyl is missing. Go and have a look at your doors, they should have the vinyl piece. I wonder if the op compared his two doors the other one should have the vinyl.
#9 Acevx220
Acevx220
  • 65 posts
Posted 20 July 2014 - 05:55 PM
Like so...
The door cars and triangles in carbon looks amazing!
#10 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 July 2014 - 06:06 PM
did you really need to quote the photos?
#11 kmidderigh
kmidderigh
  • 349 posts
Posted 21 July 2014 - 04:54 PM
great info - thanks - spot on - sticker missing from drivers side due to recent re-spray of the door. Present on passenger side.
(crack doesn't widen under pressure)
Don't suppose you can get a replacement sticker ? otherwise guess a bit of black vinyl will do....
Also tagged with one or more of these keywords: cracks, bodywork
