Steering Rack Replacement - Thoughts?
Posted 20 July 2014 - 10:56 PM
Posted 21 July 2014 - 07:57 PM
Having refurbed my Eliseparts quick-rack I know that they are indeed different than the normal Titan ones when it comes to the pivot points on the steering arms.
The basic rack is still a Titan, but the sliding rod is a little shorter and the steering arms are (as a result) longer than the ones Titan sell as a replacement.
Also (as a result) they use a smaller diameter cover for the steering arm balljoint inside the rack, because at full lock it now has to move partly inside the metal tube of the rack where the OEM rack stops with the balljoint cover just shy of the rack housing at full lock.
This means that the Elisepart steering racks move the pivot point for the steering arms more inboard compared to the OEM one and this results in a somewhat different geometry in the suspension. If this is good or bad for the bumpsteer setup I can't quantify yet, but even at fairly low ride heigths and with riser plates fitted the steering is quite stable even with un-even loading like ruts and bumps.
I don't know if the Elise-shop one uses the original geometry for the rack or not..
Posted 22 July 2014 - 06:44 AM
Posted 22 July 2014 - 08:29 PM
For me it was an improvement over the OEM rack geometry.
Had the raiser plates already fitted with the OEM rack, but the Eliseparts rack seems to have helped remove some of the direction changes on single-sided bumps even with a decent amount of toe out on the front with my current geo.
Can pretty much let go of the steering wheel at any speed and don't have to worry it will suddenly veer to one side because of a bump or rut in the road.
Posted 22 July 2014 - 08:56 PM
Posted 23 July 2014 - 07:04 PM
Also tagged with one or more of these keywords: steering rack, bump steer
The Market Place →
Car Parts For Sale →
Sona Steering Rack, Recently Greased And Compression Preset AdjustedStarted by gazbucko , 13 Oct 2019 ![]() |
The Market Place →
Group Buy Room →
Lightweight Aluminum Steering Arm Group BuyStarted by Matthew Bentley Racing Ltd , 10 Sep 2018 ![]() |
The Market Place →
Remaining Clear Out PartsStarted by gingerjon , 20 Jul 2015 ![]() |
The Market Place →
Parts For SaleStarted by wanabee , 14 May 2013 ![]() |
The Market Place →
Anyone Got A Decent Titan Oem Rack?Started by wanabee , 11 Aug 2012 ![]() |
