Oops, yep thats right.I think you mean red to green , and blue left open.Red left open Blue to green
#21
Posted 07 August 2014 - 10:35 AM
#22
Posted 07 August 2014 - 11:05 AM
brilliant thank you
#23
Posted 07 August 2014 - 11:29 AM
taking a short break from spannering this weekend to join some from friends for a party
https://www.youtube....h?v=QM5oKlJRTE0
back to the spanners tuesday
#24
Posted 07 August 2014 - 03:27 PM
mapping decision made.
posted off to peter.
#25
Posted 07 August 2014 - 03:39 PM
Good choice!mapping decision made. posted off to peter.
#26
Posted 07 August 2014 - 04:03 PM
Very good choice. Mine is sooo much nicer since it was "Petered"
#27
Posted 15 August 2014 - 07:29 AM
Had a few days off but back at it yesterday and have made good progress. Hopefully thinking about starting to put it all back together today.
All loom modifications done , and all electrics for CC system done, decided to add a fan override switch too. all information easily found on these hallowed pages ! . I have to say a massive thanks to all those that have produced such detailed and comprehensively documented build threads. I have a folder full of bookmarked threads and a set of spanners,
loom extended and tidied up
bracket made and cc pump wired up.
Fan override switch ( earthed blue/grey wire from fan relay) decided not to bother getting the led to work.
Inlet manifold and alternator fitted , (thanks Captain V for the last minute alternator supply )
WTF is the following part for , seems I ordered it from CMS??? I cant think of any water pipe that needs a bung??
Today I am going to get a bit a fibre glassing done to fix this hole
I am also considering getting a new windscreen fitted while the clam is off, anybody know if autoglass will come out to you to fit a screen on a vx or do they have to have it in their centre? a couple of reasons for this, 1. after the lunar mileage VIX has done the screen id very very scratched and pitted and with a low sun visibility is zero , also and more worryingly the entire bottom edge of the screen is not bonded down , I can lift the bottom enough to get my hand in there. . Gotta be a safety issue there.
Next question regards the PCV set up.
I have modified the gasket as per the GM book, the question is the cam breather , I know this has been discussed at length in a number of other threads but...
option 1 - Filter and catch tank and extend vent out the back somewhere , tried tested and not ideal.
option 2 - OEM and push the vented gas back through the SC - concerned about crapping up the laminovas and the SC but otherwise seems a good idea.
option 3 - catch tank and filter prior to OEM route - I like this solution but honestly don't know enough to make a educated decision
what would the "ideal" solution be??
(edit) and finally a worrying development, my ecu seems to have got lost in the north sea! posted last Thursday using royal mail, (£15!!!) and its still not got to Peter, fingers crossed it arrives today.
Edited by TIP, 15 August 2014 - 07:36 AM.
#28
Posted 15 August 2014 - 08:03 AM
Good progress fella!! Most people (as far as I know) go for option 1. Don't see there being too much of an issue with it. I had a glass catch tank and the crap that gathered in there would sure as sh*t clog the laminovas up in a matter of miles. Unless you can guarantee all the oil vapour has been filtered/caught, I would keep well away from pumping it back into the inlet manifold.
My ECU took a hell of a long time to get to Peter too, and my postage cost a lot more than £15!! Hopefully it arrives safe and sound though
#29
Posted 15 August 2014 - 08:23 AM
In obdtuner you can set the fan temp at wish, making the switch slightly unneeded.
#30
Posted 15 August 2014 - 08:24 AM
#31
Posted 15 August 2014 - 08:25 AM
#32
Posted 15 August 2014 - 08:52 AM
#33
Posted 15 August 2014 - 06:56 PM
got an email from Peter, my wayward ECU has arrived , been updated and posted back so hopefully that will arrive early next week.
Have booked auto glass to fix this mess
opps must of dropped a hammer
other wise today was spent tidying up and fettling the installation to a point where I am happy with it. (killing time really untill ECU arrives and autoglass fix the windscreen)
decided to cut the fuel lines and reroute them to the passenger side, not completely happy with this as didn't want to cut the pressure test valve off , but the existing pipe is all bendy. may live with this ???
the belt was still worrying me ( even with the fuel rerouted there is a lot of fuel filler pipe work quite close so fabbed up a guard from some spare ali
still contemplating the PCV solution , more on this as I make a decision
#34
Posted 15 August 2014 - 07:07 PM
#35
Posted 16 August 2014 - 10:38 AM
GRRRRR Autoglass are annoying, after much persuasion I finally convinced them that due to the clam already being off they DO NOT need the car in branch. (that took a lot of explaining!!) then they tell me the earliest they can come out is next Saturday , I was really hoping to get the clams on next week so I could get a weekend supercharged drive in.
Then I had to do lots of explaining that I wanted a black surround not a silver one... But they only come in silver she tells me...
Finally after nearly half hour on the phone and speaking directly to the branch manager I have a BLACK encapsulated screen coming but still have to wait till next Saturday....
#36
Posted 20 August 2014 - 06:53 PM
SHE LIVES, sort of..
I'm hoping someone will be able to diagnose a problem for me.
Having chopped and changed the fuel lines I was expecting a few problems with the first start up as the fuel filter would be empty and would all the lines and fuel rail. I primed the system by just turning the ignition on and off a few times to get the fuel pump to fill the lines and get up to pressure.
when I finally pressed the button she sprang into life hunted for revs and then dropped to firing on three cylinders , I have pulled the fuel rail and tried starting with the rail out and the squirt pattern on one of the injectors seems a bit limited (seems to be only coming from one of the holes)
have put a noid lamp on the injector plugs and all well there, so my wiring seems good , if I start her up and give it a little throttle alls good and she revs freely but after a few seconds one of the cylinder (3?) drops out and I lose the throttle. I have pulled the loom of doom plugs by the header tank apart and cleaned them but I don't think that is the problem. Also the EML is on , does anyone know if OBD tuner gives the same error codes as OEM?
First video of the engine hunting for revs and then dropping a cylinder.
http://vid667.photob...zpsc23c4c90.mp4
second video with some revs and again dropping to three cylinders (yes I know the filters not attached I was checking the throttle flap was opening since I keep losing the throttle)
http://vid667.photob...zpsf7647ab4.mp4
any ideas ??
any cheap and easy ways to clean an injector? (if I'm right and it is a crappy injector?)
Edited by TIP, 20 August 2014 - 07:01 PM.
#37
Posted 20 August 2014 - 06:55 PM
#38
Posted 20 August 2014 - 08:08 PM
Swap injectors and see if it changes cylinder
I will have a go at that tomorrow, might even try fitting the original injectors (sure it will run like shite but at least it will tell me if it is a crapped injector.
anybody got a spare LSJ injector?
#39
Posted 20 August 2014 - 11:30 PM
Joe must have some LSJ injectors lying around, but your engine is making some weird noises and not sure if it's only related to a dodgy injector.
Check the codes, as OBD-T has fully functional standard Z22SE diagnostics.
Did you rewire the TB according the correct scheme? MAP sensor or TMAP?
3 wire Delphi 2 bar MAP sensor => I see no intake tube/filter in the vids, so did you connect the IAT sensor back in?
#40
Posted 21 August 2014 - 07:22 AM
throttle body was wired using smileys 2 day conversion thread. i hope that's right.?
map sensor is the one supplied by CMS
IAT sensor is mounted in the intake tube (I took the filter off to check the throttle flap as I also lose the throttle when it misfires) but same problem with intake attached.
I will check codes today ( I didnt have my code reader yesterday and am still waiting for the usb/obd cable to arrive so I can use peters software)
thanks for the pointers
Also tagged with one or more of these keywords: supercharger, project, diy
The Market Place →
Cars Wanted →
Vx220 Wanted - ProjectStarted by dstarz7 , 14 Oct 2020 wanted, vx220, project |
General Discussion →
Tuning & Modifications →
Projects →
Resurrection Of A Moonland TurboStarted by dstarz7 , 02 Mar 2020 vx220, turbo, project, repair |
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 supercharger |
The Market Place →
Cars For Sale →
Chassis For SaleStarted by NickB787 , 12 Feb 2018 project, track, road car |
VX220 Discussion →
Bare Chassis Needed For Mock-UpStarted by WazzaVX220 , 10 Oct 2017 chassis, vx220, engine, project |
