Ok, so you're running on peters basemap atm.
Can you email that to me so i can open it in my obdtuner so i can check the parameters? (just pm me)
Your CS map sensor will be a regular 2bar one, not a tmap.
Posted 21 August 2014 - 08:00 AM
Posted 21 August 2014 - 08:05 AM
still waiting for the interface cable to arrive (hopefully friday) then I will email it to you ( thank you)
do i need a TMAP sensor or can I use the CMS supplied MAP?
just heading off to the workshop now with my cheap ebay OBD reader will post error codes asap.
Posted 21 August 2014 - 08:27 AM
In odbtuner you specify if you use the CS 2 bar map sensor, or a 2.5 bar tmap.
If you have a tmap sensor however, the wiring of your temp sensor (the one between air filter and throttle body) and the map sensor are combined.
So tmap is not just a tick in the software.
Peter is not known to make mistakes in his basemap.
He will have asked you for all your cars variables, before creating the basemap for you.
Can you post what you emailed him on parameters?
Edited by smiley, 21 August 2014 - 08:28 AM.
Posted 21 August 2014 - 08:44 AM
You can just use the CS MAP sensor, that's what I am doing and its grand. Get it up and running properly before faffing with a TMAP. As for your dodgy injectors, have you checked that the fuel rail is getting the vacuum feed from the manifold? It looks like it in the picture before, but thought I would ask. The map needs to be told what the vac/fuel rail/rail pressure setup is, but as mentioned, Peter is pretty thorough and I would be very surprised if there is a mistake in the map.
Posted 21 August 2014 - 09:06 AM
Posted 21 August 2014 - 09:15 AM
Posted 21 August 2014 - 09:19 AM
P1512:
- brown ecu relay in the back making bad connection - blue connector behind header tank bad connection (not corroded!)
P1514: - scangauge set to showing more then 3 values - faulty injector - faulty map sensor
My first bet is on loom of doom, so clean and check the 2 connectors behind the header tank first.
Posted 21 August 2014 - 09:48 AM
Posted 21 August 2014 - 10:03 AM
Edited by CHILL Gone DUTCH, 21 August 2014 - 10:03 AM.
Posted 21 August 2014 - 10:04 AM
Posted 21 August 2014 - 11:17 AM
got an email from Peter, my wayward ECU has arrived , been updated and posted back so hopefully that will arrive early next week.
Have booked auto glass to fix this mess
opps must of dropped a hammer
other wise today was spent tidying up and fettling the installation to a point where I am happy with it. (killing time really untill ECU arrives and autoglass fix the windscreen)
decided to cut the fuel lines and reroute them to the passenger side, not completely happy with this as didn't want to cut the pressure test valve off , but the existing pipe is all bendy. may live with this ???
the belt was still worrying me ( even with the fuel rerouted there is a lot of fuel filler pipe work quite close so fabbed up a guard from some spare ali
still contemplating the PCV solution , more on this as I make a decision
just check your fuel lines are correct just noticed that you have changes your fuel pipes
Edited by CHILL Gone DUTCH, 21 August 2014 - 11:26 AM.
Posted 21 August 2014 - 12:09 PM
Mine went for the three cylinder option when she started as well.
It was so simple that the plug into one of the injectors was forced out when I bolted the injectorrail into place.
Edited by OneYet, 21 August 2014 - 12:09 PM.
Posted 21 August 2014 - 02:05 PM
right frustated now!!!
all connections cleaned and checked (loom of doom, injector plugs, throttle body, ecu, map sensor)
injectors checked (all are delivering fuel)
this is the engine configuration I sent Peter (I cant check this yet as I'm waiting on the OBD interface to arrive) but I cant help thinking that Peter wont have made a mistake
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Engine compression ratio: OEM[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Desired rev limiter rpm: 6000[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]SC type: m62[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]SC pulley size: 3.3"[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Throttle body: 68 mm[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Air filter/inlet setup: courtney supplied[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]EGR valve: removed[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Injector type: green LSJ[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Charge cooling setup: pro alloy[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Exhaust setup: OEM manifold, miltek cat pipe, Janspeed back box[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Cam shafts: OEM[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Fuel pressure: OEM[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Fuel pressure regulator connected to boost: yes[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Manifold Air Pressure sensor number and position: cortney supplied in manifold[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Use Temperature sensor in TMAP for measuring intake air temperature: no[/color]
[color=rgb(54,95,145);]- [/color][color=rgb(54,95,145);]Other like cylinder head ported or other important info: none.[/color]
engine starts and hunts for revs and then drops a cylinder, if I give it some revs the throttle is silly responsive , the very slightest pressure on the pedal (2-3mm) sends the revs immediatly up to 6K.
as soon as the misfire develops (10-20 seconds) I get no response from the throttle and the EML lights up with P1514. Cleared this code a few times and each time it comes back with P1514. (as well as Smileys reading of this code (thanks)I found reference to it being something else
(the dreaded p1514 is too much intake air flow, the ecu then gets the hump. - Vocky)
I guess Im stuck untill I can connect the laptop and check the base map? although it has to be something simple , as I said cant believe Peter would make a mistake
Posted 21 August 2014 - 02:11 PM
Perhaps the throttle body is incorrectly wired?!?! Throttle shouldn't be that sensitive
Posted 21 August 2014 - 03:35 PM
You're welcome to borrow my cable but realise I'm not exactly close to you....
Once you have the cable you can log what's going on and hopefully all will become clear.
Posted 21 August 2014 - 03:50 PM
if an injector isn't firing and still does not fire after moving it to another cylinder then replace the injector, I have seen two duff LSJ injectors recently.
Posted 22 August 2014 - 10:01 AM
excellent the cable has arrived , so I am off to the workshop to get a log to send to Peter and to check the configuration, update soon
Posted 22 August 2014 - 03:42 PM
Posted 22 August 2014 - 03:44 PM
Posted 22 August 2014 - 03:46 PM
The Market Place →
Cars Wanted →
Vx220 Wanted - ProjectStarted by dstarz7 , 14 Oct 2020 ![]() |
General Discussion →
Tuning & Modifications →
Projects →
Resurrection Of A Moonland TurboStarted by dstarz7 , 02 Mar 2020 ![]() |
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 ![]() |
The Market Place →
Cars For Sale →
Chassis For SaleStarted by NickB787 , 12 Feb 2018 ![]() |
VX220 Discussion →
Bare Chassis Needed For Mock-UpStarted by WazzaVX220 , 10 Oct 2017 ![]() |
