#121
Posted 05 October 2014 - 03:53 PM
#122
Posted 05 October 2014 - 04:09 PM
I have cycled through most of the port numbers hitting the test button and nada , I have tried different baud rates too.
when I got it working on my dads laptop, I could find it in device manager and it had up to date drivers showing, on this netbook, I see an entry under 'other devices' called usb serial port , but message say no drivers installed for this device.
the clean install was from an ISO downloaded , I used the key on the back of the netbook and it all authenticated correctly but I did have to faff about quite a lot downloading, VGA drivers, network adapter drivers etc from the samsung website. just wondered if there was a dependant driver that I have failed to add to the windows reinstall?
#123
Posted 05 October 2014 - 05:23 PM
right fecked off with it now. I hate being beaten by technology.
uninstalled all drivers i downloaded, rebooted and hoped windoze would recognise the cable . nope nothing , not a bloody thing. OBDT doesnt pick it up, device manager cant see it.
going to drink rum !!
#124
Posted 05 October 2014 - 05:45 PM
in 'Device Manager' (might be another folder, but in OBD manual it has the correct folder), in 'Ports' right click on the OBD '[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:13.63636302948px;]usb serial port', click properties, click the port settings tab and change the Baud rate to 38400[/color]
Edited by vocky, 05 October 2014 - 05:47 PM.
#125
Posted 05 October 2014 - 06:17 PM
all the options are greyed out, "this device is not configured properly" ?????
#126
Posted 05 October 2014 - 06:28 PM
#127
Posted 31 December 2014 - 03:26 PM
hello all , hope everybody had a lovely chrimbo!!
I'm after some collective knowledge again..
the old girls playing up again..
since the last few exchanges on this thread I gave up with trying to get crap netbook to talk to the ecu and just enjoyed driving it, she then got 'put away' for winter , after a 4 (ish) weeks hibernation I tried to start her and nothing.
so diagnostic so far is
symptoms. engine cranks over fine but no attempt at firing
1. battery fully charged (and a pretty fresh one at that)
2 fuel rail priming and appropriate pressure at valve.
3 changed coil pack ( this did change to an almost firing once ) but then nothing.
4. it's in a garage so water etc is not an issue
5. its cold in there but certainly above freezing.
6. 3/4 tank of fuel (less than 5 weeks old)
any ideas ,
#128
Posted 31 December 2014 - 03:38 PM
following suggestions from Chill, just tried warming the MAP and inlet temp sensor with a hair drier but no joy
#129
Posted 31 December 2014 - 03:43 PM
Sounds like a boost leakfollowing suggestions from Chill, just tried warming the MAP and inlet temp sensor with a hair drier but no joy
#130
Posted 31 December 2014 - 03:56 PM
Don't see how a boost leak will stop from firing.
#131
Posted 31 December 2014 - 03:59 PM
#132
Posted 31 December 2014 - 04:02 PM
#133
Posted 31 December 2014 - 04:03 PM
Not enough oxygen to cause it firing In affect flooding it Can you check spark plugs
There's no boost at idle, so there's no difference starting a car with or without a boost leak.
#134
Posted 31 December 2014 - 04:07 PM
#135
Posted 31 December 2014 - 04:16 PM
Has the battery been charged the entire time? It sounds like an immobiliser type problem where one part of the system forgets how to talk to another.
#136
Posted 31 December 2014 - 04:27 PM
the battery got a little flat but enough to crank the engine , I thought the immobiliser allowed the engine to fire and run for a few seconds before cutting?
is there a way to reset the immobiliser ?
how can I test for a spark? I read that that sticking a plug in the coil and touching an earth can do bad things to the ecu and my spark plug testers are useless in this engine as you cant see in the deep hole.
the replacement coil pack was second hand from ebay so possibly two faulty coil packs? (unlikely though)
Edited by TIP, 31 December 2014 - 04:30 PM.
#137
Posted 31 December 2014 - 04:38 PM
Edited by haggi961, 31 December 2014 - 04:39 PM.
#138
Posted 31 December 2014 - 04:46 PM
Map sensor dead? Mine did this and a new map sensor fixed it.
anyone got a spare map sensor I could try?,
#139
Posted 31 December 2014 - 04:51 PM
If you can, hook up another car battery via jump leads to the current one. Just to make sure it's not flat. Most of these starting issues come down to the battery, both charge and how well the battery is bolted to the terminals.
#140
Posted 31 December 2014 - 05:00 PM
Tom
the engine itself cranks over really fast, with the lights on they dim a bit when cranking but still are on . the battery has been on the charger and is only about a year old. (halfords Calicium jobby)
so pretty sure the battery is good, but I will borrow a jump pack and give it a go
Also tagged with one or more of these keywords: supercharger, project, diy
The Market Place →
Cars Wanted →
Vx220 Wanted - ProjectStarted by dstarz7 , 14 Oct 2020 ![]() |
General Discussion →
Tuning & Modifications →
Projects →
Resurrection Of A Moonland TurboStarted by dstarz7 , 02 Mar 2020 ![]() |
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 ![]() |
The Market Place →
Cars For Sale →
Chassis For SaleStarted by NickB787 , 12 Feb 2018 ![]() |
VX220 Discussion →
Bare Chassis Needed For Mock-UpStarted by WazzaVX220 , 10 Oct 2017 ![]() |
