Tip's Supercharged Adventure
supercharger project diy
176 replies to this topic
#141 fezzasus
Posted 31 December 2014 - 05:05 PM
so it's fuel or spark, and with the fuel pressure being okay they both come down to a electrical problem.
Matt's suggestion of looking at the immobiliser is a good one, however I don't know where to go from there. Before you get to that point I would unplug everything that has anything to do with ignition, spray it with contact cleaner and put it back. Loom of doom plugs, injector plugs, coil pack plugs. Has it been stored inside or out, the latter would have me checking the plugs very carefully for corrosion.
Also check the relays and fuses, again spray with contact cleaner and replace. It's usually moisture that kills stationary cars.
#142 TIP
TIP
  • 959 posts
  • Interests:cars. sci-fi, rum, bass, sheds, making stuff, fixing other stuff (mainly plastic vauxhalls) and other geeky bloke stuff
Posted 31 December 2014 - 05:10 PM
thanks mate
its been inside so its all dry in there, but certainly worth a good poke around the entire electrical system (BAH! I hate electrickery)
any advice on checking for a spark?
#143 fezzasus
Posted 31 December 2014 - 05:37 PM
Pull the coil pack off and check the contacts with a bulb?
#144 Arno
Arno
  • 1,238 posts
Posted 01 January 2015 - 10:39 AM
the engine itself cranks over really fast,
Very fast crank speed can mean no or low compression in the engine.  Bores washed out with fuel?
Could try pulling the sparkplugs and squirting a little oil in each cylinder to restore the compression. Refit plugs and retry. It should crank at a normal speed then.
Edit: no other noises? (cam chain issue? :huh: )
Edited by Arno, 01 January 2015 - 10:41 AM.
#145 TIP
TIP
  • 959 posts
Posted 01 January 2015 - 12:43 PM
Hi Arno
sorry bad description, engine cranks over at the right speed, I meant that the battery is good and is cranking it over properly.
no other 'expensive' noises
pretty sure its an electrickery problem (and I don't like finding those !!!!)
#146 TIP
TIP
  • 959 posts
Posted 11 January 2015 - 01:02 PM
latest findings
  • no error codes showing on ECU
  • all boot relays cleaned up and refitted
  • all the various connectors pulled apart wiggled and reconnected
  • its too cold to work on cars
  • it still does not start.
bloody cars
Edited by TIP, 11 January 2015 - 01:09 PM.
#147 CHILL Gone DUTCH
Posted 11 January 2015 - 01:13 PM
Have you got your lap top connected yet ?? If so read ECU to PC, Save file And email it to me along with your spec could be something simple in there
#148 TIP
TIP
  • 959 posts
Posted 11 January 2015 - 04:15 PM
after much faffing about, the status is still cant connect to the ecu
I have had it connected (using my Dad's laptop so I know the cable works)
but so far I have tried
1. Samsung N150 netbook. (win7)
2 relocated desktop to the garage (win7)
3 My main Laptop (win8)
all nothing
the following are screen shots from the win 8 attempt, do they point at any obvious mistakes.
for each computer I tried just connecting the cable and letting windoze work out the installation when that failed I followed the following instructions http://www.totalcard...ware#changeport.
I then uninstalled all available drivers and restarted and tried again, and again , Grrrrrr
then tried changing port numbers still nothing.
will get hold of my Dad's laptop next week and see if that still works
edited because I thought it was bad form to publish the license key on a public forum
and just found this that points to the code 10 error (fake cable???)
http://www.prolific...._id=225&pcid=41
Edited by TIP, 11 January 2015 - 04:22 PM.
#149 CHILL Gone DUTCH
Posted 11 January 2015 - 04:18 PM
Give me 5 and I will screen shot my settings
#150 CHILL Gone DUTCH
Posted 11 January 2015 - 04:30 PM
#151 TIP
TIP
  • 959 posts
Posted 11 January 2015 - 04:32 PM
can you check what it shows in the device manager please
thanks for all the help
and what cable you have
this is what I have http://www.ebay.co.u...=item3cbe165600
Edited by TIP, 11 January 2015 - 04:35 PM.
#152 CHILL Gone DUTCH
Posted 11 January 2015 - 04:37 PM
#153 CHILL Gone DUTCH
Posted 11 January 2015 - 04:39 PM
#154 CHILL Gone DUTCH
Posted 11 January 2015 - 04:42 PM
#155 TIP
TIP
  • 959 posts
Posted 11 January 2015 - 04:44 PM
all looks the same , other than I have the code 10 error in the device manager tree.
other than the port 3/port 5 difference , but cant see how that would make a difference as long as OBD2 is looking at the correct port????
my guess is the cable is fecked , will check with the one laptop that it has worked on before buying another.
#156 CHILL Gone DUTCH
Posted 11 January 2015 - 04:45 PM
try it just with the cable not connecte[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]d to car[/color]
#157 CHILL Gone DUTCH
Posted 11 January 2015 - 04:54 PM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]do you have a [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]driver on [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]disc for cable ??[/color]
#158 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 January 2015 - 05:01 PM
Has anyone got the EGR input rates for the software using a Aem wideband ?
#159 TIP
TIP
  • 959 posts
Posted 11 January 2015 - 05:08 PM
I cant find the discs that came with the cable (been some major decorating going on at home since last time I saw the disc) but have used the drivers listed here to no avail
#160 CHILL Gone DUTCH
Posted 11 January 2015 - 05:13 PM
Try to set bit rate to 9600 I think it is in device manager and software
Also tagged with one or more of these keywords: supercharger, project, diy
