Hi Guys, Finally the VSE is on & pre-cat de-cat completed. PITA job, but worth doing.... One thing though... Exhaust tips of the VSE vibrate (quite alarmingly & at a high frequency).
See video here: https://www.dropbox.... Vibrations.MOV
Unfortunately, frame rate on the iPhone is not high enough to capture true movement (what appears as a "wobble" in the video is actually a vibration, I'd say in an upward - downward motion of about 2-3mm each way).
There are no "extra" rattles, knocks or vibration in the cabin & I checked the u-bend pipe, cat & pre-cat pipes which seem pretty solid. What say ye.... don't f**k with it or under- trays off & rehang whole system?
Oh.... whilst I was under there found an oil leak... Not too bad (not even noticed it on the dip stick), but it is making a mess! Buggered is I can find where it's coming from, any ideas (maybe head gasket seal)?
Photo One: https://www.dropbox.... Oil Leak 1.JPG
Photo Two: https://www.dropbox.... Oil Leak 2.JPG
as always cheers in advance. Ben.
