ps. is there anything better than a nice evening drive?
Couldn't agree more, that time of day is always when I enjoy the car most, so much fun on a sunny evening around the forest. Where did you take these?
Sweet, I went for snow foam, triple polish, and passion wax plus some extras. Is it best to spray snow foam straight onto the car with the jetwash or get the car wet first? Going to clay it Saturday then start with polish and wax.
I'm no detailing expert mate but think you snow foam, let it settle for a few mins, jet off with water, then snow foam again, then use a wash mit and water (two buckets etc) to go over it.
Wash mit is, in my honest opinion, not the way to go these days. I detail cars as a hobby and have found the best way (and fastest way) to do a proper job as follows (zero bucket method!):
Rinse
Iron x. Dwell. Rinse
Tar remover. Dwell. Rinse
Foam. Dwell. Rinse
Foam. Use clean mf towels to wash the car, when used put them aside to launder. Rinse
Clay. Dry
Polish
Seal
Wax
Drive it!
That's just the body so add in glass polish, wheels, pipes, roof etc.
Also when machine polishing the VX, normal paint gauges don't work so err on the side of caution and use a jewellers polish with a soft pad, I would rather leave any heavy swirls on the car than risk taking all the paint off!
It all sounds like a lot of work but spraying and letting it dwell isn't exactly taxing, and you want to touch the car as little as possible as you wash it. The bulk of the correction I do for people is fixing 'love marks' from washing.
That's very interesting Peter, it seems there's a new way to do it every time I look into it!! I really enjoy detailing so always open to new methods, I will have to give that a go soon. Im just never sure if I should spray the foam straight on or wet the car first. Seems like the foam won't be as effective if the Car is wet as it runs off quicker I suppose.
I must admit I normally do the two bucket method after snow foam has been applied.I then give it a good dry with mf towels. Then I use either use a spray wax or a glaze called poor boys black hole which I've found to be good. My favourite correctional polish has to be scratch x though, it's amazing! Then I use autoglym HD wax.
Have to see how well the autofinesse stuff is, certainly has good reviews!
Edited by Andy_VX, 14 August 2014 - 01:21 AM.
