Noisy Evap Valve
23 replies to this topic
#1 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 06 August 2014 - 06:23 AM
The evap valve has got really noisy. Has anyone changed one? Is it a clam off job or can you get to it via the wheel arch? How much are they? etc etc TIA
#2 techieboy
Posted 06 August 2014 - 06:30 AM
I've changed one and you can do it through the wheelarch, Chris. It's a bit awkward as it has those horrible hose clips designed by the devil, so be prepared for a scrape or two. No idea what the cost of the solenoid on it's own is as I got a secondhand one complete with the charcoal canister.
#3 Sutol
Sutol
  • 8,122 posts
Posted 06 August 2014 - 07:40 AM
Thanks Matt, I won't do it I'll get BOT to do it if there's a risk of injury. Was yours making a horrible clattering noise at startup and then disappearing after a while?
#4 siztenboots
Posted 06 August 2014 - 08:12 AM
how do you plumb in your EVAP with vacuum , on the SC setup
#5 Sutol
Sutol
  • 8,122 posts
Posted 06 August 2014 - 08:44 AM
err there were no alterations made over the NA setup. This system is a mystery to me. This clattering noise comes from the area of the evap valve ie over the right shoulder. It's always been there but it's much worse now. Should alterations been made when SCing?
#6 P11 COV
P11 COV
  • 7,683 posts
Posted 06 August 2014 - 08:46 AM
whats an EVAP valve and whats does it do?
#7 siztenboots
bleeds fumes from the fuel tank / filler via a carbon canister , using vacuum in the manifold and then burnt
#8 Sutol
Sutol
  • 8,122 posts
Posted 06 August 2014 - 09:02 AM
so how does this system get the fumes into the intake?
#9 p13
p13
  • 192 posts
Posted 06 August 2014 - 09:12 AM
It gets sucked in to the intake through vacuum.  The valve opens periodically.
#10 p13
p13
  • 192 posts
Posted 06 August 2014 - 09:13 AM
I've simply removed mine, and plan to bridge the connector with a resistor.
#11 techieboy
Posted 06 August 2014 - 09:20 AM
No, no noises or anything from mine. I was just trying to solve a persistent P0440 EML code that I get every start up. Didn't make a difference so I think it's probably a wiring fault with the cable that gets extended for the SC conversion.
#12 Sutol
Sutol
  • 8,122 posts
Posted 06 August 2014 - 09:47 AM
before the TB or after it? the valve opens relative to the engine speed, is this right?
#13 p13
p13
  • 192 posts
Posted 06 August 2014 - 09:53 AM
After it.  There is no vacuum before the TB.
I think it just opens and closes fully.  It probably pulses open and shut.
The plug for it is just two wires.  Electrically, it's very simple.
#14 rickyzero
rickyzero
  • 229 posts
Posted 06 August 2014 - 05:04 PM
Could it be described as a loud ticking noise from over your right shoulder? I'm wondering if the evap valve could be my issue. I've changed everything else!
#15 Sutol
Sutol
  • 8,122 posts
Posted 06 August 2014 - 08:16 PM
sounds like it, changes with engine speed. The noise is only at startup and goes after a few miles but its got worse and sounds like the lltte  ends have gone,
#16 siztenboots
Posted 07 August 2014 - 07:23 AM
if you could find the vacuum pipe that feeds it , and pinch it off to block it, then see if ticking is still there from cold.
#17 rickyzero
rickyzero
  • 229 posts
Posted 07 August 2014 - 03:44 PM
Ah will give this a try. Is the vacuum pipe accessible from the engine bay do you know?
Also, if it is the valve, what part am I looking for. Is it number 34 on this diagram?
#18 siztenboots
Posted 08 August 2014 - 07:45 AM
#19 siztenboots
Posted 08 August 2014 - 07:51 AM
while trying to eliminate vacuum leaks at high vacuum , low engine load , ie. fuel economy cruising.
I blanked off the vacuum feed to my EVAP system ( just by the manifold ) , and I get noticeably better mpg. 280miles from a tank is not unusual, with a 32L fill up brimmed.
#20 sammyt
sammyt
  • 102 posts
Posted 08 August 2014 - 01:51 PM
I changed mine was easy to do and access through the wheel arch. My symptoms were the same as yours plus I had a uneven tick over due to the leaking vacuum caused by the valve passing. Changed this valve out for a new OEM one at 25 quid and it fixed all my problems in 10 minutes
